Hi everyone,
I’ve installed the HACS integration for my Worx Landroid mower in Home Assistant. Everything seems to be working fine in terms of status updates, but I’m having trouble changing the Torque setting using the provided slider.
Whenever I try to adjust the torque value, I get the following error message:
Failed to call service number/set_value. No connection to AwSIoT MQTT
My mower appears online in the official Worx app, and Home Assistant has full internet access. The device status updates regularly in Home Assistant, but it seems like commands (like setting the torque) aren’t going through.
What could be causing this MQTT connection issue?
Is there a way to manually restore or re-authenticate the connection to the Worx cloud?
Any help or hints would be appreciated!
Thanks in advance.
