I’m new to LVGL and I tried to do a simple hello world but when I install it I get the following error “error configTASK_NOTIFICATION_ARRAY_ENTRIES must be at least 1” if I compile with esp-if and get " error: ‘EFUSE_BLK0_RDATA3_REG’ was not declared in this scope" if I use ardurino as a framework.
Any help would be greatly appreciated.
esphome:
friendly_name: kitchen-info
platformio_options:
board_build.flash_mode: dio
build_flags:
- "-DBOARD_HAS_PSRAM"
- "-DconfigTASK_NOTIFICATION_ARRAY_ENTRIES=1"
board_build.arduino.memory_type: qio_opi
board_build.psram_type: opi
board_upload.maximum_size: 16777216
board_upload.maximum_ram_size: 524288
esp32:
board: esp32-s3-devkitc-1
variant: esp32s3
flash_size: 16MB
framework:
type: esp-idf
sdkconfig_options:
CONFIG_ESP32S3_DEFAULT_CPU_FREQ_240: "y"
CONFIG_ESP32S3_DATA_CACHE_64KB: "y"
CONFIG_ESP32S3_DATA_CACHE_LINE_64B: "y"
CONFIG_SPIRAM_FETCH_INSTRUCTIONS: y
CONFIG_SPIRAM_RODATA: y
psram:
mode: octal
speed: 80MHz
# Enable logging to view the output in logs
logger:
hardware_uart: UART0
# SPI Configuration for ILI9488
spi:
clk_pin: GPIO14
mosi_pin: GPIO11
miso_pin: 12 # Not used in ILI9488, can be left unconnected
# TFT Display Configuration
display:
- platform: ili9xxx
model: ILI9488
cs_pin: GPIO5
dc_pin: GPIO16
reset_pin: GPIO18
rotation: 90
invert_colors: false
auto_clear_enabled: false
update_interval: never
lvgl:
displays:
- my_display
widgets:
- label:
align: CENTER
text: 'Hello World!'
