Cant connect to HA cloud provided link
I cant connect to HA cloud provided link:
# curl -v https://blahblahblah.ui.nabu.casa/
* Host blahblahblah.ui.nabu.casa:443 was resolved.
* IPv6: (none)
* IPv4: 144.126.246.47
*   Trying 144.126.246.47:443...
* Connected to blahblahblah.ui.nabu.casa (144.126.246.47) port 443
* ALPN: curl offers h2,http/1.1
* TLSv1.3 (OUT), TLS handshake, Client hello (1):
*  CAfile: /etc/ssl/certs/ca-certificates.crt
*  CApath: /etc/ssl/certs
* OpenSSL SSL_connect: SSL_ERROR_SYSCALL in connection to blahblahblah.ui.nabu.casa:443
* Closing connection
curl: (35) OpenSSL SSL_connect: SSL_ERROR_SYSCALL in connection to blahblahblah.ui.nabu.casa:443
The home Assistant itself shows
Cloud connection status: connected
The subscription is active. I tried this from several locations but with the same result. HA version is 2026.1.3
It takes a bit for the address to populate in the worlds database. How long did you wait?
today it’s ok. You’re right.
Hi, good that it got solved!
Also: please take the time to mark the post that holds the answer.
You do that by selecting the three dots under the post:
Then select the check box:
By doing so:
  • this thread can be useful to other users as well (this thread comes up as solution when starting a thread which is similar to yours).
  • this prevents that someone else steps in trying to help
Thanks for giving back to the community! :+1:
