Hello , just bought used HA green .
I reset it to clear all data from previus owner and was able to connect to it .
Then i did an update and needed to reboot it , and now i cant connect anymore .
What should i do ?
White light is on , as well as blinking orange light .
Try to read this
https://support.nabucasa.com/hc/en-us/sections/25139705229725-Troubleshooting .
And also perform the basic hardware/software troubleshootings
Like clear browser cache ALL-Everything, try to access from another Device ( In the same Network ( And Not from an old configured Companion APP on your Phone )
So when you have done some troubleshooting, please report back , with a detailed description of what you have done, in Order etc, and i.e post a picture of your Green’s CLI ( Connect a monitor and keyboard to your Green, then you will see the startup-process and the CLI, you can also , when it up and running, type --help , and after each command you can also type --help
I.E type
ha net inf -help
PS: It should blinking orange and yellow, when it eventually get a network connection, so also check your Router, to see whether it’s in there( got an IP number, and is Registret on your network )
PS: If you just Updated HA( Installed ), you should NOT Using :8123 after the IP-Number, or the HostName Addresses … New in lastest Release
So try to use these
http://homeassistant
http://homeassistant.local
http://IP-number
