Can't connect to hassio-local:8123
I have setup a new hassio on a pi 3b device. The instruction says open a browser can connect to the home assistance by using the http://hassio.local:8123
I have config a usb with system-connections file for the wifi setting. I’m not able to connect via a browser and can not find what IP address it has.
I connected the PI to a monitor, keyboad and mouse. I get a message welcome to HassOS
It prompts me to login, I use root and no password and I get the hassio > prompt
I am stuck here. how do I find the ip address that the PI has? I like to connect to it via the browser to finish setting it up.
I looked for command line document on hassio but with out much luck.
any help would be great.
Sidney
What address does your router say it has?
My router says it’s Ip as 192.168.1.184
I tried that address but it gives me page can’t be displayed. Http://192.168.1.184:8123
I am trying to confirm it’s IP address from the raspberry pi device.
I also have this problem.
I have the same problem
Same here; access to …duckdns works while access to …internal_IP or hassio.local in https:// has stopped working after upgrade to 0.106.2
I have a similar issue, after updating a fresh install to the latest version, it now says “Connection refused” And wont display the lovelace interface or anything
The same, it just stopped responding on the requests from yesterday
