Can't connect to HomeAssistant after a domain change
Hey Guys,
my HomeAssistant was available at a xxx.duckdns.org domain and everything was great. Then i wanted to replace the domain with another .duckdns.org domain.
Since i did the replacement i am not able to log in to HomeAssistant via the new Domain. I can enter my User and password but then the message “Unable to connect to Home Assistant” is displayed.
I am using the DuckDns plugin, i changed the domain there and also in the http component.
Do you have any ideas why this is happening
Thank you
Did you make sure ports 80 and 443 are forwarded on your router?
I’m not using the plugin but configured it on ducksdns.org and replaced my IP a couple of months ago.
Can you provide your configuration etc. in this post? An image sometimes is worth a thousand words :slight_smile:
I found the issue.
Checked port forwarding it was fine. But i also enabled DynDns in my router for a test i did. So i disabled it and everything is fine.
Thank you
