Hi there,
I am lost. This is the first time I wanted to set up Home Assistant. I purchased an Intel Nuc and flashed the interal SSD with the newest image as found per the official documentation (I used Method 1).
Home Assistant seems to be running fine. It says “System is ready! Use the browser or app to configure.”.
I can reach the Observer URL just fine. But I cannot for the life of me reach the Home Assistant URL. I tried homeassistant.local:8123, I tried the IP address of home assistant with the port at the end but it just says This site can’t be reached
homeassistant.local refused to connect.
I downgraded the version from 2026.1.0 to 2025.12.5 since I’ve saw a post reporting a similar issue when trying to reach the UI of HA a couple of days ago running this newest version. Still no success.
When I try to rebuild the core it encounters an unknown error. if i look at the supervisor logs it says home assistant has crashed again. Restarting the router, home assistant or anything else hasn’t work either.
I’m lost. What am I missing? Any help is greatly appreciated.
Best,
a new, desperate HA user.
