Can't contact update server
Anyone else seeing this?
ERROR (MainThread) [homeassistant.components.updater] Could not contact Home Assistant Update to check for updates
Since 0.52.1 I’ve been getting this once a day. I’m not sure if the updater checks more often successfully, or if this is the only shot and I’m forever stuck on 0.52.1 because it can no longer see the update server.
Same here! I install hassio (0.52.1) yesterday and today i saw 3 times error checking for updates. In hassio/advanced settings l have 0.52.1 latest and current version but today they release version 0.53.
This seems to be unrelated to wether using hass.io or not, I have the same problem on hassbian 0.56.2
Whatever was causing that, it resolved a few days later and I’ve had no problems since
