Hi.
I’m starting to play with node-red and I’m trying to ‘detect’ when bridghtness is changed for specific light.
First, I can’t get “event: state” for this…I don’t know why, but isn’t trigged when I change btight, just when I turn on/off the light.
But using “trigger: state” works and it’s triggered when I just change the brightness value. The problem is that “Switch” node isn’t doing anything with this output from trigger node. Why? What am doing wrong?
I already debugged message and changed to correct object in switch node, but still not working.
In your state_change node make sure to UNCHECK:
Current state equal previous state
Otherwise you will not get an attribute change since the state stays on
As for the rest, can you please export your flow and share it please?
This makes it much easier to help you.
Tks, it worked now with “event: state” node! The switch still not working.
Here’s the flow:
[{"id":"25dbaffd.77cbd","type":"tab","label":"Debuga","disabled":false,"info":""},{"id":"5771958c.6b8b5c","type":"server-state-changed","z":"25dbaffd.77cbd","name":"","server":"2ba92c0c.9dae24","version":1,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"light.74467000600194f5eeee","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":false,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"x":570,"y":380,"wires":[["65ce99c1.364ab8"]]},{"id":"65ce99c1.364ab8","type":"debug","z":"25dbaffd.77cbd","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1090,"y":360,"wires":[]},{"id":"f9c5261.506c2d8","type":"api-call-service","z":"25dbaffd.77cbd","name":"","server":"2ba92c0c.9dae24","version":1,"debugenabled":false,"service_domain":"light","service":"turn_on","entityId":"light.74467000600194f5eeee","data":"{\"brightness_pct\": 15}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":720,"y":720,"wires":[[]]},{"id":"ed465104.3a5df","type":"inject","z":"25dbaffd.77cbd","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":430,"y":720,"wires":[["f9c5261.506c2d8"]]},{"id":"5546db44.898af4","type":"inject","z":"25dbaffd.77cbd","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":430.0000915527344,"y":800.000186920166,"wires":[["b4e6af5a.82532"]]},{"id":"b4e6af5a.82532","type":"api-call-service","z":"25dbaffd.77cbd","name":"","server":"2ba92c0c.9dae24","version":1,"debugenabled":false,"service_domain":"light","service":"turn_on","entityId":"light.74467000600194f5eeee","data":"{\"brightness_pct\": 100}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":718.0000839233398,"y":801.0001640319824,"wires":[[]]},{"id":"699e9413.348bbc","type":"trigger-state","z":"25dbaffd.77cbd","name":"","server":"2ba92c0c.9dae24","exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityid":"light.74467000600194f5eeee","entityidfiltertype":"exact","debugenabled":false,"constraints":[],"outputs":2,"customoutputs":[],"outputinitially":false,"state_type":"str","x":560,"y":500,"wires":[["d825ce8.8c6793","4bb56309.24841c"],[]]},{"id":"d825ce8.8c6793","type":"debug","z":"25dbaffd.77cbd","name":"D1","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1060,"y":500,"wires":[]},{"id":"4bb56309.24841c","type":"switch","z":"25dbaffd.77cbd","name":"","property":"data.event.new_state.attibutes.brightness","propertyType":"msg","rules":[{"t":"lte","v":"50","vt":"num"},{"t":"gte","v":"200","vt":"num"}],"checkall":"true","repair":false,"outputs":2,"x":930,"y":560,"wires":[["28c6239b.bce47c"],["4c4fb0e6.dc1fe"]]},{"id":"28c6239b.bce47c","type":"api-call-service","z":"25dbaffd.77cbd","name":"","server":"2ba92c0c.9dae24","version":1,"debugenabled":false,"service_domain":"light","service":"turn_off","entityId":"light.74467000600194f5eeee","data":"{\"flash\":\"long\"}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1260,"y":560,"wires":[[]]},{"id":"4c4fb0e6.dc1fe","type":"api-call-service","z":"25dbaffd.77cbd","name":"","server":"2ba92c0c.9dae24","version":1,"debugenabled":false,"service_domain":"light","service":"turn_on","entityId":"light.74467000600194f5eeee","data":"{\"brightness_pct\":100, \"effect\": \"random\", \"flash\": \"long\"}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1250,"y":620,"wires":[[]]},{"id":"2ba92c0c.9dae24","type":"server","name":"Home Assistant","legacy":false,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true}]
try this:
[{"id":"1ac8bf58.313d71","type":"server-state-changed","z":"70124295.5e68f4","name":"","server":"2fba4297.e4145e","version":1,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"light.desklamp","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":false,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"x":310,"y":240,"wires":[["8ff1cd93.e458b"]]},{"id":"8ff1cd93.e458b","type":"switch","z":"70124295.5e68f4","name":"","property":"data.new_state.attributes.brightness","propertyType":"msg","rules":[{"t":"lte","v":"50","vt":"num"},{"t":"gte","v":"200","vt":"num"}],"checkall":"true","repair":false,"outputs":2,"x":530,"y":340,"wires":[["910626b0.9b22e8"],["554cfd35.a197a4"]]},{"id":"910626b0.9b22e8","type":"debug","z":"70124295.5e68f4","name":"small","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":730,"y":320,"wires":[]},{"id":"554cfd35.a197a4","type":"debug","z":"70124295.5e68f4","name":"big","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":730,"y":400,"wires":[]},{"id":"2fba4297.e4145e","type":"server","name":"Home Assistant","legacy":false,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true}]
You should get two different messages in the debug log. This will show you that the switch node actually works. I think the problem might be with your service calls. i.e.: turn off service call cannot be coupled with a flash.
It worked! Tks!
That flash and turn on/off was just for testing…the debug messages worked fine, so the switch is working!
