I have an Amazon thermostat and ADT control panel I want to control with HA. I set up Nabu Casa and some input booleans to trigger events in Alexa. They only worked sometimes. After some searching, I read that template binary sensors are more reliable so I set them up. They work in HA in that I added them to overview and when I toggle the switch, the sensors open and close as expected. However they are not seen by Alexa. They cant be exposed in UI because they were setup in conifg so I exposed them in config as well but they still aren’t seen. Please help me understand what I am missing.
Yaml…
> # Loads default set of integrations. Do not remove.
> default_config:
> # Load frontend themes from the themes folder
> frontend:
> themes: !include_dir_merge_named themes
> automation: !include automations.yaml
> script: !include scripts.yaml
> scene: !include scenes.yaml
> http:
> use_x_forwarded_for: true
> trusted_proxies:
> - 172.30.33.0/24
> # For Alexa routines
> template:
> binary_sensor:
> - name: "Alarm Away"
> device_class: door
> state: "{{ is_state('input_boolean.alarm_away', 'on') }}"
> - name: "Alarm Stay"
> device_class: door
> state: "{{ is_state('input_boolean.alarm_stay', 'on') }}"
> - name: "Sleeping"
> device_class: door
> state: "{{ is_state('input_boolean.sleeping', 'on') }}"
> cloud:
> alexa:
> filter:
> include_entities:
> - binary_sensor.alarm_away
> - binary_sensor.alarm_stay
> - binary_sensor.sleeping
