I’m new to Home Assistant, so… I just bought a Rheem heat pump water heater, which has an RJ11 port for Eco-Net. I looked here for the connection hardware, but nobody seems to have the RS-485 base part of it in stock.
Does anyone know where to find it, or, an alternative to use? Thanks
Thanks. I was kinda hoping for something that was more of a finished product with a case, connectors, etc. But, if this is how it’s done, I guess I can figure it out.
Maybe try the “ATOM Tail485”… and pair it with an Atom S3 Lite? You would not be able to power from the USB-C port, but would have to power from RS485 at ~ 12VDC.
Thanks for the advice, but I don’t really have enough experience to know what to pick yet, I spent some time yesterday researching. By the way, I found this on Aliexpress, it’s a little pricey, should I consider trying it?
I’ve installed ESPHome, done the configuration, and installed the firmware onto the Atom, but it doesn’t do anything. It looks like it created a base config, but none of the actual control code.
Looking at “esphome-econet/econet_heatpump_water_heater.yaml” on github, none of this code is in the yaml it created. There’s also an include that it’s looking for:
With a fair amount of research, I got this working yesterday (not sure if it’s right, but I’m getting data). Today I received notification that the latest RS-485 parts are in stock. Here’s some pictures and the rheem-hpwh.yaml configuration I used.
