I’m trying to setup the HomeKit bridge integration. For some reason, it is not available in the list of integrations when I select Configuration->Integrations->"+". The HomeKit Controller integration is available to be added, but not the bridge. If I manually set things up by editing configuration.yaml, it seems to work, but I’d really like to be able to configure things in the UI.
Any suggestions on how to get it to show up?
I’m using HassIO on a Raspberry Pi 4. I’m currently running Home Assistant Core v0.109.6.
