I have been using hass.io on docker for a while with no problems, I had copied my old system over from a Pi into a docker, everything was working well until recently.
The Ducks DNS addon Log in Supervisor tab shows the SSL certificate as being up to date (expires at a future date), but when navigating to the frontend, all browsers (I have reset tha caches) show that the SSL cert is out of date.
When I use SAMBA to check the files on the hass.io docker instance, in the root directory I can see an ssl folder which had the 2 certificate PEM files that have not been modified for 4 months (around the time I moved to docker).
In the config folder there is also an ssl sub folder, this is empty.
I can not find where Duckdns is storing the updated SSL PEM files, but it is checking them so they must exist somewhere. How can I locate them or point my configurations to them?
Duckdns log:
NOCHANGE
#INFO: Using main config file /data/workdir/config
Processing -xxxxxx.duckdns.org
- Checking domain name(s) of existing cert… unchanged.
- Checking expire date of existing cert…
- Valid till Dec 31 15:15:57 2020 GMT Certificate will not expire
(Longer than 30 days). Skipping renew!
Duck DNS config:
lets_encrypt:
accept_terms: true
certfile: fullchain.pem
keyfile: privkey.pem
token: (Removed)
domains:
-xxRemoved.duckdns.org
aliases: []
seconds: 300
Configuration file:
http:
#Secrets are defined in the file secrets.yaml
’ #base_url: ‘https://-removedxx.duckdns.org:8123’
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
