Can't find reason for error log
I got the following error:
Sun Feb 23 2020 18:43:21 GMT+0100 (Mitteleuropäische Normalzeit)
Error during template condition: UndefinedError: 'None' has no attribute 'state'
Erfolgreich gespeichert
This error appears every 2.5 Minutes.
I checked every template in automation, sensors, binary sensors and switches.
All templates are working.
Where could that come from.
I’m on a fresh installed 105.3 and rasp 3+
My guess without seeing any config is that you are doing this somewhere
states.sensor.my_sensor.state
rather than
states('sensor.my_sensor')
If the entity you are referring to is unavailable, even temporarily, you will get these errors using the first type of usage.
See warning in this section. There are multiple suggested methods.
Thanks, I will try it.
You’re right, I use the first version.
ok, I changed that. But this doesn’t solve my issue.
There must be something else.
As it is around every 2.5 Minutes, I guess that must be a sensor or binary_sensor.
I dont’t have automations running in such a frequency.
Is that assumtion right? Or do I miss something?
Do you have a lot of templates? If not, please post them here and we can take a look.
I have tons of templates, I try it:
Here are the relevant sensors:
    sensors:
      days_to_leave:
        friendly_name: 'Tage bis Urlaub'
        value_template: '{{ (as_timestamp(states.calendar.gmail_urlaub.attributes.start_time) /86400 - as_timestamp(as_timestamp(now()) | timestamp_custom("%Y-%m-%d 00:00:00",true)) /86400) |int }}'
        unit_of_measurement: 'Tage'
      active_harmony_scene:
        friendly_name: 'Aktive Szene'
        value_template: '{{ state_attr("remote.wohnzimmer", "current_activity") }}'
      next_sunrise:
        friendly_name: Sunrise
        value_template: '{{ as_timestamp(states.sun.sun.attributes.next_rising) | timestamp_custom("%H:%M") }}'
      next_sunset:
        friendly_name: Sunset
        value_template: '{{ as_timestamp(states.sun.sun.attributes.next_setting) | timestamp_custom("%H:%M") }}'
      cover_livingroom_position:
        friendly_name: 'Position Rollo WZ'
        value_template: '{{state_attr("cover.rolladen_wohnzimmer", "current_position")}}'
        unit_of_measurement: '%'
      cover_kitchen_position:
        friendly_name: 'Position Rollo Küche'
        value_template: '{{state_attr("cover.rolladen_kuche", "current_position")}}'
      last_called_alexa:
        entity_id:
          - media_player.wohnzimmer
          - media_player.schlafzimmer
          - media_player.kuche
          - media_player.gastezimmer
          - media_player.office
          - media_player.fitnessraum
        value_template: >
         {%- for entity in states.media_player -%}
           {%- if state_attr(entity.entity_id, 'last_called') == True -%}
             {{ entity.entity_id }}
           {%- endif -%}
         {%- endfor -%}
      office_temperature:
        friendly_name_template: "Office Temperatur"
        value_template: >
         {{ states.sensor.office.state |float + 2 |round(1) }}
        unit_of_measurement: '°C'
      waschmaschine_watts:
        friendly_name_template: "{{ states.switch.waschmaschine.name}} Aktueller Verbrauch"
        value_template: >
          {% if states.switch.waschmaschine.attributes.current_power_w %}
           {{ states.switch.waschmaschine.attributes["current_power_w"] | float }}
          {% else %}
           -1
          {% endif %}
        unit_of_measurement: 'W'
      waschmaschine_today_kwh:
        friendly_name_template: "{{ states.switch.waschmaschine.name}} heutiger Verbrauch"
        value_template: >
          {% if states.switch.waschmaschine.attributes.today_energy_kwh %}
           {{ states.switch.waschmaschine.attributes["today_energy_kwh"] | float }}
          {% else %}
           -1
          {% endif %}
        unit_of_measurement: 'kWh'
      trockner_watts:
        friendly_name_template: "{{ states.switch.trockner.name}} Aktueller Verbrauch"
        value_template: >
          {% if states.switch.trockner.attributes.current_power_w %}
           {{ states.switch.trockner.attributes["current_power_w"] | float }}
          {% else %}
           -1
          {% endif %}
      trockner_today_kwh:
        friendly_name_template: "{{ states.switch.trockner.name}} heutiger Verbrauch"
        value_template: >
          {% if states.switch.trockner.attributes.today_energy_kwh %}
           {{ states.switch.trockner.attributes["today_energy_kwh"] | float }}
          {% else %}
           -1
          {% endif %}
      outside_temperature:
        friendly_name_template: "Außenttemperatur"
        value_template: >
         {% if states('input_select.weather_mode') == 'Netatmo' %}
          {{ states('sensor.netatmo_imeerbus121_garten_temperature') }}
         {% else %}
          {{ states('sensor.yr_temperature') }}
         {%- endif %}
      outside_humidity:
        friendly_name_template: "Luftfeuchtigkeit außen"
        value_template: >
          {{ states('sensor.netatmo_imeerbus121_garten_humidity') }}
         {% else %}
          {{ states.sensor.yr_humidity.state }}
         {%- endif %}
      outside_wind_speed:
        friendly_name_template: "Windstärke"
        value_template: >
          {{ states('sensor.netatmo_imeerbus121_wind_garten_wind_strength') }}
         {% else %}
          {{ (states('sensor.yr_wind_speed') |float * 3.6) |round(1) }}
         {%- endif %}
        unit_of_measurement: 'km/h'
      outside_rain:
        friendly_name_template: "Regen aktuell"
        value_template: >
          {{ states('sensor.netatmo_imeerbus121_rs_garten_sum_rain_1') |float |round(2) }}
         {% else %}
          {{ states('sensor.yr_precipitation') }}
         {%- endif %}
        unit_of_measurement: 'mm'
      outside_pressure:
        friendly_name_template: "Luftdruck"
        value_template: >
          {{ states('sensor.netatmo_imeerbus121_wohnzimmer_pressure') }}
         {% else %}
          {{ states('sensor.yr_pressure') }}
         {%- endif %}
        unit_of_measurement: 'hPa'
      current_motion_location:
        friendly_name_template: "Bewegung Ort"
        value_template: >
         {% if states('binary_sensor.presence_26') == 'on' %}
          Wohnzimmer
         {% elif states('binary_sensor.presence_35') == 'on' %}
          Treppe oben
         {% elif states('binary_sensor.presence_32') == 'on' %}
          Treppe unten
         {% elif states('binary_sensor.presence_29') == 'on' %}
          Schlafzimmer
         {% elif states('binary_sensor.presence_2') == 'on' %}
          Office
         {% elif states('binary_sensor.presence_5') == 'on' %}
          'Gästezimmer'
         {% elif states('binary_sensor.presence_8') == 'on' %}
          Fitnessraum
         {% else %}
          ruhig
         {%- endif %}
      temperature_trend:
        friendly_name: 'Temperatur Trend'
        value_template: >
          {% if states('binary_sensor.temp_rising') == 'on' %}
            Up
          {% elif states('binary_sensor.temp_falling') == 'on' %}
            Down
          {% else %}
            stable
          {% endif %}
and the relevant binary_sensors:
    sensors:
      all_lights_state:
        value_template: >
          {{ is_state('group.all_light_groups', 'on') }}
        device_class: light
      open_window:
        value_template: >
          {{ is_state('group.check_window', 'on') }}
        device_class: door
      washer_state:
        value_template: >
          {{ is_state('variable.washing_mode', 'on') }}
        device_class: power
      dryer_state:
        value_template: >
          {{ is_state('variable.dryer_mode', 'on') }}
        device_class: power
      notebook_joerg:
        value_template: >
          {{ is_state('device_tracker.pc19er', 'home') }}
        device_class: connectivity
      desktop_yvonne:
        value_template: >
          {{ is_state('device_tracker.desktop_gnesrek', 'home') }}
      homematic_online:
        value_template: >
           {{ states('sensor.access_point') |int > 1 or states('sensor.access_point') != 'unknown' }}
      netatmo_online:
        value_template: >
           {{ states('device_tracker.netatmo_personal_weather_station') == 'home' }}
I see you are still using states.xxx.xxx notation in a lot of templates. Try changing all of them to the states(xxxx) notation as @MatthewFlamm suggested.
I found the bug!!!
In the end, you forced me, to check and change all templates in my automations.
I have 155 - puh…
There I found this one:
- id: '20012'
  alias: Alert when a critical device goes offline
    - platform: state
      entity_id: binary_sensor.homematic_online, binary_sensor.netatmo_online
      to: 'Offline'
      for:
        minutes: 5
  condition:
    condition: and
    conditions:
      - condition: template
        value_template: >
          {% if states.automation.alert_when_a_critical_device_goes_offline.last_triggered is not none %}
            {% if as_timestamp(now()) | int   -  as_timestamp(states.automation.alert_when_a_critical_device_goes_offline.attributes.last_triggered) | int > 3600 %} true {% else %} false
            {% endif %}
          {% else %}
          false
          {% endif %}
The trigger pointed to a sensor, which had to be renamed during my new installation of 105.3.
I changed the sensor to a binary one.
But I will change the notation of the other templates step by step :slight_smile: I swear.
Thank you.
