Can't find way to filter integration from logbook
I've tried understanding the documentation, googling, searching this forum etc. without luck/a solution.
The integration Browser Mod is producing a lot of unecessary and useless noise in Activity/logbook. I don't mind the data being recorded, but I have no use of seeing the data except if I'm specifically interested in it.
How can I achieve this? Thanks in advance!
What entities in Browser Mod are being noisy? I get almost nothing from the integration.
Anyways Browser Mod only has 4 entity domains so far as I know, so as per the Activities docs this should work...
logbook:
  exclude:
    entity_globs:
      - sensor.browser_mod_*
      - binary_sensor.browser_mod_*
      - light.browser_mod_*
      - media_player.browser_mod_*
It's possible that a single list item like *.browser_mod_* might work as well but I have not tried it, maybe others can weigh in on that.
Thank you!
No entities in particular, I just can't understand why I can't filter an entire integration from the logbook as presenting the aforementioned data in this case often is unecessary and I'd prefer manually opening the entities or checking system logs if necessary.
The solution in this case was renaming all devices belonging to browser mod with the prefix browser:mod and excluding based on your first suggestion, in this case:
logbook:
  exclude:
    entity_globs:
I attempted your second suggestion, but an error due to unidentified alias ".browser_mod_*".
Thanks @HappyCadaver!
