Cant Flash ESP32-T8-C3
Hello, i cant Flash the ESP-C3 Vers. T8-C3 V1.0
I use an RPi 4 with HA OS.
I use the USB C Connection.
What is wrong?
Greetings from Germany
You can’t access your serial port. Not ha or esphome issue.
What can i do to fix it?
Doesnt work. Is there an Tutorial so i can check the right way?
Try the web flasher, and press the button (if there is one) while inserting
Now he is connecting, but more not.
There is 2 Buttons.
Normally it is the button labeled ‘boot’
To flash: Press and hold BOOT, then press and release Reset, then release BOOT
Connect and bevor “Install”?
Press and Hold Boot…
Now i can Flash. Bus is no Connection to ESPHome.
The Green LED is out.
T8-C3 v1.0
ESP-C3 Risc-V
esphome:
  friendly_name: ESP-C3
esp32:
  board: esp32-c3-devkitm-1
  framework:
    type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "******************************************************"
ota:
  - platform: esphome
    password: "************************************"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Esp-C3 Fallback Hotspot"
    password: "**********"
captive_portal:
@Breacher If you try my method you won’t have to hold Boot for ages while it flashes which is why I suggested it.
Why are you using the Arduino framework? It is not what is recommended. Read the fine manual!
Where can i find it?
esphome.io of course.
Specifically ESPHome Docs — ESPHome
