and enabled it as an assist device but pressing the button does nothing, also using the voice command (I renamed the wake word to “Hey assistant”) does nothing either, it says that wake word is disabled even though I’ve enabled it.
I did that a while ago, so there’s absolutely no guarantee that I remember this correctly - but here’s a try.
After adopting it, I created my own yaml file for the device by copying the code from the link to the package on GitHub (m5stack.atom-echo-wake-word-voice-assistant) and added (or modified an existing?) binary sensor:
binary_sensor:
- platform: gpio
pin:
number: GPIO39
inverted: true
disabled_by_default: true
entity_category: diagnostic
on_multi_click:
- timing:
- ON for at least 250ms
- OFF for at least 50ms
then:
- voice_assistant.stop: # Stop any ongoing session
- delay: 1s
- voice_assistant.start: # Start listening manually
The button shows up in the ‘Diagnostic’ section of the device - it might be the entity that’s disabled for your device - and I can see that it reacts when I press the button to invoke the voice_assistant.start
binary_sensor:
- platform: status
- platform: gpio
pin:
number: GPIO39
inverted: true
on_multi_click:
- timing: #single short click
- ON for at most 700ms
- OFF for at least 1s
then:
- logger.log: "Single Short Clicked"
- if:
condition:
- switch.is_on: timer_ringing
then:
- switch.turn_off: timer_ringing
else:
- timing: #double click
- ON for at least 50ms
- OFF for at most 500ms
then:
- logger.log: "Double Clicked"
- script.execute: start_wake_word
- timing: #long click 25 second
- ON for at least 25s
then:
- logger.log: "Long Click 30"
- button.press: restart_btn
and below is script so you can see what wake_word_start does
I made small changes to the default esphome code for atom echo so I didnt post full.
I havent used this device in a month so no garuntee but I am 98% sure this was working perfect since adding button was last thing I did before I receive my new voice devices and my echos were working at that time (i think )
Yes. asking for YAML from esphome device builder. I am thinking that is what you are calling “ESPHome WebUI” but not sure. It is not this
Pretty much Yes. These are section taken from our YAML so you will you will need to find, for example, the “binary_sensor” section of the existing yaml and add the “- platform…” pieces. You cant have multiple binary sensor sections if that makes sense? You will verify what we put does not already exist and add the missing pieces. If you post your yaml we can edit it in to make it easier. Hence the “post your yaml”.
ESP devices are fun! I would first get it back to functioning Post the yaml and we can help. The device builder will not compile bad code so not much worry about breaking things. ( I said “not much” not “none at all”). You have to try hard to break things really. You likely just removed the section controlling lights or something. If you have original yaml you used post that if not we can work with what you have.
