Can't get binary sensor to show an entity attribute
I am trying to make something display on my dashboard based on whether a thermostat in my heatmiser system is calling for heat in a given zone. The thermostat has an attribute called hvac_action.
If I examine the entity climate.utility_room_neo in developer tools I can see:
hvac_modes:
  - heat_cool
min_temp: 5
max_temp: 35
friendly_name: Utility Room Neo
supported_features: 1
current_temperature: 19.7
temperature: 24
hvac_action: heating
The attibute hvac_action changes to idle when the heating is off in that zone.
I created a binary sensor using this code:
binary_sensor:
  - name: "Utility Is Heating"
    unique_id: utility_is_heating
    state: >
        is_state('states.climate.utility_room_neo.attributes.hvac_action', 'heating')
My understaning of the above is that the binary sensor called utility_is_heating should be ON when the attribute hvac_action is ‘heating’ and OFF the rest of the time.
Howver, if I go to developer tools->template and enter:
'{{ states.climate.utility_room_neo.attributes.hvac_action }}'
the resulting output is:
Result type: string
'heating'
but the value of binary_sensor.utility_is_heating is OFF
Can anyone tell me what I’m doing wrong please?
You have mashed up the is_state() function and state object method. The function expects an entity ID and a state as arguments. You have provided a string-ified version of the attribute path for your state object and a state.
Just use the is_state_attr() function and supply the correct arguments; entity ID, attribute name, value:
binary_sensor:
    state: >
      {{ is_state_attr('climate.utility_room_neo', 'hvac_action', 'heating') }}
Thanks for your reply. Looking at the documentation I see what you mean - is_state_attr is what I should be using. However I still can’t seem to get this to report correctly.
Code in my templates.yaml is:
binary_sensor:
    state: >
Developer Tools → Template → Template Editor
Returns the folllowing result:
Result type: boolean
true
This template listens for the following state changed events:
Entity: climate.utility_room_neo
Developer->States->binary_sensor.utility_is_heating returns
state: unavailable
I assume I’m doing something blindingly obvious wrong, because if I go to a UI created dashboard, add an Entity card and pick binary_sensor.utility_is_heating, not only is the status Unavailable, I also have a warning message that says:
This entity is no longer being provided by the template integration. If the entity is no longer in use, delete it in settings.
I don’t suppose you can see anything that jumps out as obviously wrong? I’m sure it’s something simple but I just can’t see it :frowning:
    state: >
Way too many template braces there. Remove the outer or inner pair of {{ }}.
You are an absolute superstar - thank you kindly :slight_smile:
Working code / solution as follows:
binary_sensor:
    state: >
