Hi Home Assistant Community,
I registered with callmebot for both whatsapp and signal messenger
I’m unable to use signal messenger via Home Assistant to send notify messages. It only works fine in Home Assistant for whatsapp notify messages.
this is what I did on /config/configuration.yaml for both whatsapp & signal messenger:
Note: changed actual phone, uuid and api to random number
notify:
- name: WhatsApp
platform: rest
resource: https://api.callmebot.com/whatsapp.php
source: HA
phone: +12345678910
apikey: 1234567
- name: signal
platform: rest
resource: https://api.callmebot.com/signal/send.php?
phone: 25a7d32b-0c51-44d8-b11b-c5bc73294abc
apikey: 123456
Note in signal I used UUID instead of phone number because it works in the browser test.
Test:
Tested Whatsapp via web browser and it works (received message in whatsapp):
https://api.callmebot.com/whatsapp.php?phone=12345678910&text=This+is+a+test&apikey=1234567
Tested Signal via web browser and it works (received message in signal app):
https://api.callmebot.com/signal/send.php?phone=25a7d32b-0c51-44d8-b11b-c5bc73294abc&apikey=123456&text=This+is+a+test
Some reference links I used as guidelines:
HA Whatsapp setup
Not sure what is wrong any help appreciated.
Thanks in advance.
