JABIoT
November 28, 2020, 9:43pm
1
I have D1 Mini ver 3.0.0
Hassio 0.118.3
ESPhome 1.15.3
This is my simple code:
esphome:
platform: ESP8266
board: d1_mini
wifi:
ssid: "JAB-CAN"
password: "xxxxxxxxx"
# Enable logging
logger:
level: DEBUG
I was using ESPHome-Flasher-1.2.0
upgraded to version 1.3.0 (same problem)
After flashing this is the log I get:
Using 'COM4' as serial port.
Connecting....
Detecting chip type... ESP8266
Connecting....
Chip Info:
- Chip Family: ESP8266
- Chip Model: ESP. (92 %)Writing at 0x00034000... (100 %)Wrote 309824 bytes (223297 compressed) at 0x00000000 in 5.1 seconds (effective 486.8 kbit/s)...
Hash of data verified.
Leaving...
Hard Resetting...
Done! Flashing is complete!
Showing logs:
[16:18:18][I][logger:166]: Log initialized
[16:18:18][I][app:029]: Running through setup()...
[16:18:18][C][wifi:033]: Setting up WiFi...
[16:18:18][D][wifi:324]: Starting scan...
[16:18:24][D][wifi:339]: Found networks:
[16:18:24][I][wifi:385]: - 'JAB-CAN' (86:83:C2:97:xx:xx) ▂▄▆█
[16:18:24][D][wifi:386]: Channel: 6
[16:18:24][D][wifi:387]: RSSI: -55 dB
[16:18:24][I][wifi:194]: WiFi Connecting to 'JAB-CAN'...
[16:18:31][W][wifi_esp8266:395]: Event: Disconnected ssid='JAB-CAN' bssid=86:83:C2:97:xx:xx reason='Auth Expired'
[16:18:31][W][wifi:485]: Error while connecting to network.
[16:18:31][W][wifi:522]: Restarting WiFi adapter...
[16:18:31][W][wifi_esp8266:395]: Event: Disconnected ssid='JAB-CAN' bssid=86:83:C2:97:xx:xx reason='Authentication Failed'
[16:18:31][I][wifi:194]: WiFi Connecting to 'JAB-CAN'...
[16:18:31][W][wifi_esp8266:191]: wifi_apply_hostname_(kitchenleds): lwIP error -16 on interface st (index 0)
[16:18:37][W][wifi_esp8266:395]: Event: Disconnected ssid='JAB-CAN' bssid=86:83:C2:97:xx:xx reason='Auth Expired'
[16:18:37][W][wifi:485]: Error while connecting to network.
[16:18:37][W][wifi:522]: Restarting WiFi adapter...
I am obviously sure of my ssid password, also tried a different ssid/password.
I tried another D1 Mini and getting same issue.
Anything else I can try?
nickrout
(Nick Rout)
November 28, 2020, 9:56pm
2
Have you rebooted the esp?
Are there any special chars in your password?
JABIoT
November 28, 2020, 10:12pm
3
I have rebooted the esp multiple times. I reduced my password to contain only numbers.
I’ve been going at this for a few hours now. I’ve also tried from https://github.com/espressif/esptool to run esptool.py erase_flash and then flashed the bin file again.
I had a bigger .bin file but it is now down to the minimal as shown in my first post.
nickrout
(Nick Rout)
November 28, 2020, 10:23pm
4
Have you tried moving the device closer to your AP?
opened 04:47PM - 20 Feb 20 UTC
closed 05:41PM - 01 Apr 20 UTC
Operating environment/Installation (Hass.io/Docker/pip/etc.):
esphome run in command line mode on a Mac (Sierra) against a NodeMCU ESP32S-WROOM v1.1 board with a minimal...
Google throws up a number of issue threads on esphome.
JABIoT
November 28, 2020, 10:51pm
5
Distance to the AP is about 10 feet. D1 Mini never connected. It detects all of my neighbours APs (removed from my initial post) it looks like as soon as it tries to connect, the Wifi part restarts.
I am starting to pull hair out…
JABIoT
November 29, 2020, 4:39am
6
After further extensive evaluation my D1 Mini modules are defective. All 5 of them, that was a roll of dice purchasing on Aliexpress.
nickrout
(Nick Rout)
November 29, 2020, 6:23am
7
Bummer. Very boring to buy stuff and get duds.
K3iVi
March 19, 2021, 2:51pm
8
Had the same problem. Only thing that helped was to disable 5ghz wifi on my ubiquiti.
I got the same problem, could fix it by define all my BSSID for my wifi like this, and double checked my password
You should find the BSSID by searching for the wifi,or in the wificonfigs of the Accesspoint.
esphome:
platform: ESP8266
board: d1_mini
wifi:
networks:
- ssid: Meinwifiname
bssid: A3:02:14:CF:7F:40
password: MeinWifiPasswort
bssid: 25:E8:BE:C0:1B:f2
bssid: F0:D2:84:6E:7E:53
bssid: 4C:84:0D:52:63:A0
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
password: "THmmD3"
ota:
password: "THmmD3"
- platform: ultrasonic
trigger_pin: D1
echo_pin: D2
stevemann
(Stephen Mann (YAML-challenged))
March 27, 2021, 9:05pm
10
I have purchased 15-20 Wemos d1 minis, NodeMCU’s, and esp8266-01’s from Ali Express. Not a dud in the lot.
ciB
July 28, 2021, 11:14pm
11
I’m having a similar issue. Also the fallback captive_portal is not working. It says it’s starting, but my I cannot see it. I have tested with another D1 mini and it worked. I assume there is some issue with wifi antenna…
zumheulen
(zumheulen)
July 26, 2022, 8:09am
12
Very nice… nothing seems to have changed.
Also I have two D1 Mini V3 through Aliexpress. The bitchy already when describing, then they cannot be found via WLAN.
I’ll try the tip with the BSSID before they end up in the trash. :-))
nickrout
(Nick Rout)
July 26, 2022, 11:11am
13
What on earth does that mean?
stevemann
July 26, 2022, 2:24pm
14
Flag on the field.
You changed your WiFi password on the router?
poudenes
(Poudenes)
November 24, 2022, 12:38pm
16
I have same issue. Everything is correct. Wifi ssid name, password just letters and numbers.
When powered off and later on powered on its connect sometimes.
Current version: 2022.11.2 Addon in HA
Moved some ESP modules from ESPeasy to ESPhome. On ESPeasy everything worked without any issue… on ESPhome always the connection problems:
[I][wifi:257]: WiFi Connecting to 'Oudenes.Photography'...
[W][wifi_esp8266:212]: wifi_apply_hostname_(meek-livingroom): lwIP error -16 on interface st (index 0)
[W][wifi_esp8266:482]: Event: Disconnected ssid='Oudenes.Photography' bssid=[redacted] reason='Association Leave'
[W][wifi:549]: Error while connecting to network.
[W][wifi:585]: Restarting WiFi adapter...
[W][wifi_esp8266:482]: Event: Disconnected ssid='Oudenes.Photography' bssid=[redacted] reason='Auth Expired'
[W][wifi_esp8266:482]: Event: Disconnected ssid='Oudenes.Photography' bssid=[redacted] reason='Authentication Failed'
config:
esphome:
esp8266:
board: nodemcuv2
logger:
api:
encryption:
key: "HIDDEN"
ota:
password: "HIDDEN"
wifi:
ssid: Oudenes.Photography
password: HIDDEN
power_save_mode: none
reboot_timeout: 30min
fast_connect: true
mqtt:
broker: 192.168.100.24
username: HIDDEN
password: HIDDEN
client_id: esphome-livingroom
topic_prefix: esphome/livingroom
discovery: true
light:
- platform: neopixelbus
default_transition_length: 0s
type: GRB
variant: 800KBPS
pin: D4
num_leds: 2
name: "ESPHome livingroom - Neopixel1"
- platform: partition
name: "ESPHome Partition - neopixel1"
default_transition_length: 1s
segments:
- id: neopixel
to: 0
name: "ESPHome Partition - neopixel2"
segments:
- id: neopixel
to: 1
switch:
- platform: gpio
pin: D1
name: "ESPHome livingroom - Switch 1"
- platform: gpio
pin: D1
name: "ESPHome livingroom - Switch 2"
binary_sensor:
- platform: gpio
pin: D5
name: "ESPHome livingroom - Touch 1"
on_press:
- switch.toggle: switch1
- if:
condition:
switch.is_on: switch1
then:
- light.turn_on:
brightness: 100%
red: 0%
green: 100%
blue: 0%
- if:
condition:
switch.is_off: switch1
then:
- if:
condition:
lambda: |-
return id(goodnight).state > 0;
then:
- light.turn_on:
brightness: 100%
red: 10%
green: 0%
blue: 10%
- if:
condition:
lambda: |-
return id(kodi).state > 0;
then:
- light.turn_on:
brightness: 100%
red: 93%
green: 0%
blue: 93%
- if:
condition:
lambda: |-
return id(daytime).state > 0;
then:
- light.turn_on:
brightness: 100%
red: 100%
green: 0%
blue: 0%
- if:
condition:
lambda: |-
return id(evening).state > 0;
then:
- light.turn_on:
brightness: 100%
red: 100%
green: 0%
blue: 0%
- if:
condition:
lambda: |-
return id(appletv).state > 0;
then:
- light.turn_on:
brightness: 100%
red: 55%
green: 55%
blue: 0%
- if:
condition:
lambda: |-
return id(tv).state > 0;
then:
- light.turn_on:
brightness: 100%
red: 0%
green: 25%
blue: 53%
- if:
condition:
lambda: |-
return id(nintendo).state > 0;
then:
- light.turn_on:
brightness: 100%
red: 36%
green: 28%
blue: 55%
- platform: gpio
pin: D7
name: "ESPHome livingroom - Touch 2"
on_press:
- switch.toggle: switch2
- if:
condition:
switch.is_on: switch2
then:
- light.turn_on:
brightness: 100%
red: 0%
green: 100%
blue: 0%
- if:
condition:
switch.is_off: switch2
then:
- if:
condition:
lambda: |-
then:
- light.turn_on:
brightness: 100%
red: 10%
green: 0%
blue: 10%
- if:
condition:
lambda: |-
then:
- light.turn_on:
brightness: 100%
red: 93%
green: 0%
blue: 93%
- if:
condition:
lambda: |-
then:
- light.turn_on:
brightness: 100%
red: 100%
green: 0%
blue: 0%
- if:
condition:
lambda: |-
then:
- light.turn_on:
brightness: 100%
red: 100%
green: 0%
blue: 0%
- if:
condition:
lambda: |-
then:
- light.turn_on:
brightness: 100%
red: 55%
green: 55%
blue: 0%
- if:
condition:
lambda: |-
then:
- light.turn_on:
brightness: 100%
red: 0%
green: 25%
blue: 53%
- if:
condition:
lambda: |-
then:
- light.turn_on:
brightness: 100%
red: 36%
green: 28%
blue: 55%
# SCENES
- platform: mqtt_subscribe
name: "ESPHome livingroom - Daytime"
accuracy_decimals: 0
topic: homeassistant/scenes/daytime
on_value:
then:
if:
condition:
lambda: 'return x > 0;'
then:
- light.turn_on:
brightness: 100%
red: 100%
green: 0%
blue: 0%
name: "ESPHome livingroom - Evening"
topic: homeassistant/scenes/evening
on_value:
then:
if:
condition:
then:
- light.turn_on:
brightness: 100%
red: 100%
green: 0%
blue: 0%
name: "ESPHome livingroom - Goodnight"
topic: homeassistant/scenes/goodnight
on_value:
then:
if:
condition:
then:
- light.turn_on:
brightness: 100%
red: 20%
green: 31%
blue: 9%
name: "ESPHome livingroom - AppleTV"
topic: homeassistant/scenes/appletv
on_value:
then:
if:
condition:
then:
- light.turn_on:
brightness: 100%
red: 55%
green: 55%
blue: 0%
name: "ESPHome livingroom - Kodi"
topic: homeassistant/scenes/kodi
on_value:
then:
if:
condition:
then:
- light.turn_on:
brightness: 100%
red: 93%
green: 0%
blue: 93%
name: "ESPHome livingroom - Nintendo"
topic: homeassistant/scenes/nintendo
on_value:
then:
if:
condition:
then:
- light.turn_on:
brightness: 100%
red: 36%
green: 28%
blue: 55%
name: "ESPHome livingroom - TV"
topic: homeassistant/scenes/tv
on_value:
then:
if:
condition:
then:
- light.turn_on:
brightness: 100%
red: 0%
green: 25%
blue: 53%
# MOTION
name: "ESPHome livingroom - Motion"
topic: homeassistant/motion/livingroom
on_value:
then:
if:
condition:
then:
- light.turn_on:
brightness: 100%
red: 0%
green: 0%
blue: 100%
else:
- if:
condition:
then:
- light.turn_on:
brightness: 100%
red: 0%
green: 100%
blue: 0%
else:
- if:
condition:
lambda: |-
then:
- light.turn_on:
brightness: 100%
red: 100%
green: 0%
blue: 0%
- if:
condition:
lambda: |-
then:
- light.turn_on:
brightness: 100%
red: 10%
green: 0%
blue: 10%
- if:
condition:
lambda: |-
then:
- light.turn_on:
brightness: 100%
red: 100%
green: 0%
blue: 0%
- if:
condition:
lambda: |-
then:
- light.turn_on:
brightness: 100%
red: 93%
green: 0%
blue: 93%
- if:
condition:
lambda: |-
then:
- light.turn_on:
brightness: 100%
red: 55%
green: 55%
blue: 0%
- if:
condition:
lambda: |-
then:
- light.turn_on:
brightness: 100%
red: 0%
green: 25%
blue: 53%
- if:
condition:
lambda: |-
then:
- light.turn_on:
brightness: 100%
red: 36%
green: 28%
blue: 55%
- if:
condition:
then:
- light.turn_on:
brightness: 100%
red: 0%
green: 100%
blue: 0%
else:
- if:
condition:
lambda: |-
then:
- light.turn_on:
brightness: 100%
red: 100%
green: 0%
blue: 0%
- if:
condition:
lambda: |-
then:
- light.turn_on:
brightness: 100%
red: 10%
green: 0%
blue: 10%
- if:
condition:
lambda: |-
then:
- light.turn_on:
brightness: 100%
red: 100%
green: 0%
blue: 0%
- if:
condition:
lambda: |-
then:
- light.turn_on:
brightness: 100%
red: 93%
green: 0%
blue: 93%
- if:
condition:
lambda: |-
then:
- light.turn_on:
brightness: 100%
red: 55%
green: 55%
blue: 0%
- if:
condition:
lambda: |-
then:
- light.turn_on:
brightness: 100%
red: 0%
green: 25%
blue: 53%
- if:
condition:
lambda: |-
then:
- light.turn_on:
brightness: 100%
red: 36%
green: 28%
blue: 55%
nickrout
(Nick Rout)
November 26, 2022, 10:21pm
17
Is 5ghz enabled on your ap? Turn it off to see if it connects.
