Can't get Dark sky to work
I’m running HASS.IO…this is the error I get when I run check configeration
Configuration validation
Validate your configuration if you recently made some changes to your configuration and want to make sure that it is all valid
Configuration invalid
Invalid config for [sensor.darksky]: required key not provided @ data[‘monitored_conditions’]. Got None. (See ?, line ?). Please check the docs at https://home-assistant.io/components/sensor.darksky/
this is my configeration.yaml
  - platform: darksky
    api_key: !secret dark_sky
    monitor_conditions:
      - temperature
      - apparent_temperature
      - temperature_max
      - temperature_min
      - humidity
      - precip_probability
      - precip_intensity
      - precip_type
      - pressure
      - wind_bearing
      - wind_speed
      - icon
Can you format your config properly or paste it on hastebin.com
It should be monitored_conditions and not monitor_conditions
Thank you it worked
