Can't get DSMR reader to work
Hi all,
I can’t seem to get my DSMR-reader via ESPHOME to work.
In the past i’ve succesfully read the data, but not sure what i had as firmware on the ESP8266 back then, think it was something uploaded via Arduino.
Now, i’d like to get it to work with ESPHOME, and therefor i’m using the below config, but all states stay on ‘unknown’ and having errors in the log.
substitutions:
  devicename: dsmr-reader
  long_devicename: "Irrigation Manager"
esphome:
  platform: ESP8266
  board: nodemcuv2
# esp8266:
#   board: esp01_1m
# Enable Home Assistant API
api:
ota:
  password: "69e28e5028360201255506904329393c"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Fallback $devicename"
    password: !secret wifi_fallback_pw
web_server:
  port: 80
# Example configuration for ESP8266
logger:
  baud_rate: 0
  level: VERBOSE
uart:
  # rx_pin: D7
  rx_pin: GPIO13
  baud_rate: 115200
  # baud_rate: 9600
  data_bits: 7
  parity: NONE
  stop_bits: 1
dsmr:
  crc_check: false
  - platform: dsmr
    energy_delivered_tariff1:
    energy_delivered_lux:
    voltage_l1:
    voltage_l2:
    voltage_l3:
    power_delivered:
text_sensor:
  - platform: dsmr
    identification:
    p1_version:
    gas_delivered_text:
      name: "gas delivered raw"
But, the reader keeps saying in the logs:
[09:19:11][C][wifi:358]:   Hostname: 'dsmr-reader'
[09:19:11][C][wifi:360]:   Signal strength: -84 dB ▂▄▆█
[09:19:11][V][wifi:362]:   Priority: 0.0
[09:19:11][C][wifi:364]:   Channel: 1
[09:19:11][C][wifi:365]:   Subnet: 255.255.255.0
[09:19:11][C][wifi:366]:   Gateway: 192.168.30.1
[09:19:11][C][wifi:367]:   DNS1: 192.168.30.1
[09:19:11][C][wifi:368]:   DNS2: 0.0.0.0
[09:19:11][C][logger:233]: Logger:
[09:19:11][C][logger:234]:   Level: VERBOSE
[09:19:11][C][logger:235]:   Log Baud Rate: 0
[09:19:11][C][logger:236]:   Hardware UART: UART0
[09:19:11][C][uart.arduino_esp8266:102]: UART Bus:
[09:19:11][C][uart.arduino_esp8266:104]:   RX Pin: GPIO13
[09:19:11][C][uart.arduino_esp8266:106]:   RX Buffer Size: 256
[09:19:11][C][uart.arduino_esp8266:108]:   Baud Rate: 115200 baud
[09:19:11][C][uart.arduino_esp8266:109]:   Data Bits: 7
[09:19:11][C][uart.arduino_esp8266:110]:   Parity: NONE
[09:19:11][C][uart.arduino_esp8266:111]:   Stop bits: 1
[09:19:11][C][uart.arduino_esp8266:113]:   Using hardware serial interface.
[09:19:11][C][dsmr:275]: DSMR:
[09:19:11][C][dsmr:276]:   Max telegram length: 1500
[09:19:11][C][dsmr:277]:   Receive timeout: 0.2s
[09:19:11][C][dsmr:286]:   energy_delivered_tariff1 'dsmr_energy_delivered_tariff1'
[09:19:11][C][dsmr:286]:     Device Class: 'energy'
[09:19:11][C][dsmr:286]:     State Class: 'total_increasing'
[09:19:11][C][dsmr:286]:     Unit of Measurement: 'kWh'
[09:19:11][C][dsmr:286]:     Accuracy Decimals: 3
[09:19:11][C][dsmr:286]:   energy_delivered_lux 'dsmr_energy_delivered_tarifflux'
[09:19:11][C][dsmr:286]:   voltage_l1 'dsmr_voltage_l1'
[09:19:11][C][dsmr:286]:     Device Class: 'voltage'
[09:19:11][C][dsmr:286]:     State Class: 'measurement'
[09:19:11][C][dsmr:286]:     Unit of Measurement: 'V'
[09:19:11][C][dsmr:286]:     Accuracy Decimals: 1
[09:19:11][C][dsmr:286]:   voltage_l2 'dsmr_voltage_l2'
[09:19:11][C][dsmr:286]:   voltage_l3 'dsmr_voltage_l3'
[09:19:11][C][dsmr:286]:   power_delivered 'dsmr_power_delivered_total'
[09:19:11][C][dsmr:286]:     Device Class: 'power'
[09:19:11][C][dsmr:286]:     Unit of Measurement: 'kW'
[09:19:11][C][dsmr:289]:   identification 'dsmr_identification'
[09:19:11][C][dsmr:289]:   p1_version 'dsmr_p1_version'
[09:19:11][C][dsmr:289]:   gas_delivered_text 'gas delivered raw'
[09:19:11][C][web_server:129]: Web Server:
[09:19:11][C][web_server:130]:   Address: dsmr-reader.local:80
[09:19:11][C][mdns:084]: mDNS:
[09:19:11][C][mdns:085]:   Hostname: dsmr-reader
[09:19:11][V][mdns:086]:   Services:
[09:19:11][V][mdns:088]:   - _esphomelib, _tcp, 6053
[09:19:11][V][mdns:090]:     TXT: version = 2022.3.1
[09:19:11][V][mdns:090]:     TXT: mac = 483fda7f3e91
[09:19:11][V][mdns:090]:     TXT: platform = ESP8266
[09:19:11][V][mdns:090]:     TXT: board = nodemcuv2
[09:19:11][C][ota:085]: Over-The-Air Updates:
[09:19:11][C][ota:086]:   Address: dsmr-reader.local:8266
[09:19:11][C][ota:089]:   Using Password.
[09:19:11][V][dsmr:142]: Header of telegram found
[09:19:12][W][dsmr:092]: Timeout while reading data for telegram
[09:19:12][V][component:199]: Component dsmr took a long time for an operation (0.28 s).
[09:19:12][V][component:200]: Components should block for at most 20-30ms.
[09:19:12][C][api:138]: API Server:
[09:19:12][C][api:139]:   Address: dsmr-reader.local:6053
[09:19:12][C][api:143]:   Using noise encryption: NO
[09:19:12][V][dsmr:142]: Header of telegram found
[09:19:13][W][dsmr:092]: Timeout while reading data for telegram
[09:19:13][V][component:199]: Component dsmr took a long time for an operation (0.29 s).
[09:19:13][V][component:200]: Components should block for at most 20-30ms.
[09:19:13][V][dsmr:142]: Header of telegram found
The DSMR-device i’m having has the following ‘type number’ on it:
ESMR
I’m using a ESP8266 NodeMCU V2 connected to p1 on D7
Anyone able to spot an error?
