Can't get external_component to work with local files
Disclaimer: I tried to get help from chatgpt.
We had issues with getting external components to work, so we cut it down to the most basic: hello_world.
It seems like the external component isn’t being used
We are probably missing something obvious.
The output from compiling is this:
Processing helloworldtest (board: esp32-c3-devkitm-1; framework: arduino; platform: platformio/[email protected])
HARDWARE: ESP32C3 160MHz, 320KB RAM, 4MB Flash
 - toolchain-riscv32-esp @ 8.4.0+2021r2-patch5
Dependency Graph
|-- WiFi @ 2.0.0
|-- ESPmDNS @ 2.0.0
Compiling .pioenvs/helloworldtest/src/main.cpp.o
Compiling .pioenvs/helloworldtest/lib18f/WiFi/WiFiAP.cpp.o
/config/hello_world_test.yaml: In lambda function:
/config/hello_world_test.yaml:14:24: error: expected type-specifier before 'HelloWorld'
       auto hello = new HelloWorld();
/config/hello_world_test.yaml:16:20: error: could not convert '{hello}' from '<brace-enclosed initializer list>' to 'std::vector<esphome::Component*>'
       return {hello};
Compiling .pioenvs/helloworldtest/lib18f/WiFi/WiFiClient.cpp.o
*** [.pioenvs/helloworldtest/src/main.cpp.o] Error 1
========================== [FAILED] Took 3.75 seconds ==========================
external_components:
  - source:
      type: local
      path: my_components
    components: [hello_world]
esphome:
  platform: ESP32
custom_component:
  - lambda: |-
      App.register_component(hello);
      return {hello};
logger:
wifi:
  ssid: !secret wifi_ssid
tree config/my_components/hello_world
config/my_components/hello_world/
├── esphome.yaml
├── hello_world.cpp
├── hello_world.h
└── __init__.py
esphome.yaml
name: "Hello World Component"
files:
  - hello_world.h
  - hello_world.cpp
hello_world.cpp
#include "hello_world.h"
hello_world.h
#error "hello_world.h included"  <-- test, this does not trigger
#pragma once
#include "esphome.h"
class HelloWorld : public Component {
 public:
  void setup() override {
    ESP_LOGI("hello_world", "Hello, World!");
init.py
# Empty file to register the component
Not sure what garbage ChatGPT is giving you, but I’m pretty sure {hello} is not a valid way to reference a variable/pointer in Ardunio (which is what you’re doing when you use a lambda). Try return hello; as a start.
This is a mixup of custom components (which are no longer supported) and external components. chatgpt is generally worse than useless when dealing with esphome.
@pkscout the return {hello}; was actually valid and correct in that context.
