Can't get LD1125H working with ESPHome and D1 Mini
Has anyone gotten this to work? My config is below
esphome:
  friendly_name: Master Bedroom mmWave
  on_boot:    #LD1125H Initial Setting
    priority: -200
    then:
      - uart.write:
          data: !lambda |-
            std::string th1st = "mth1=" + str_sprintf("%.0f",id(LD1125H_mth1).state) +"\r\n";
            return std::vector<uint8_t>(th1st.begin(), th1st.end());
      - uart.write:
          data: !lambda |-
            std::string th2st = "mth2=" + str_sprintf("%.0f",id(LD1125H_mth2).state) +"\r\n";
            return std::vector<uint8_t>(th2st.begin(), th2st.end());
      - uart.write:
          data: !lambda |-
            std::string th3st = "mth3=" + str_sprintf("%.0f",id(LD1125H_mth3).state) +"\r\n";
            return std::vector<uint8_t>(th3st.begin(), th3st.end());
      - uart.write:
          data: !lambda |-
            std::string rmaxst = "rmax=" + str_sprintf("%.1f",id(LD1125H_rmax).state) +"\r\n";
            return std::vector<uint8_t>(rmaxst.begin(), rmaxst.end());
esp8266:
  board: d1_mini
# Enable logging
logger:
  baud_rate: 0
# Enable Home Assistant API
api:
  encryption:
    key: "redacted"
ota:
  password: "redacted"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Master-Bedroom-Mmwave"
captive_portal:
external_components:
  - source:
      type: git
      url: https://github.com/ssieb/custom_components #Thanks for @ssieb components.
    components: [ serial ]
uart:
  rx_pin: GPIO3  #ESP8266 UART_0
  tx_pin: GPIO1  #ESP8266 UART_0
  baud_rate: 115200
  data_bits: 8
  stop_bits: 1
  parity: NONE
globals:
  - id: LD1125H_Last_Time
    type: time_t
    restore_value: no
    initial_value: time(NULL)
  - id: LD1125H_Last_Mov_Time
    type: time_t
    restore_value: no
  - id: LD1125H_Clearence_Status
    type: bool
    restore_value: no
    initial_value: "false"
status_led:
  pin:
    number: GPIO2 #ESP8266 OnBroad LED
    inverted: false
interval:
  - interval: 1s #Clearance Scan Time
    setup_priority: -200
    then:
      lambda: |-
        if ((time(NULL)-id(LD1125H_Last_Time))>id(LD1125H_Clear_Time).state) {
          if ((id(LD1125H_Clearence_Status) == false) || (id(LD1125H_Occupancy).state != "Clearance")) {
            id(LD1125H_Occupancy).publish_state("Clearance");
            id(LD1125H_Clearence_Status) = true;
          if (id(LD1125H_MovOcc_Binary).state == true) {
            id(LD1125H_MovOcc_Binary).publish_state(false);
          if (id(LD1125H_Mov_Binary).state == true) {
            id(LD1125H_Mov_Binary).publish_state(false);
number:
    name: LD1125H mth1 #mth1 is 0~2.8m Sensitivity.
    icon: "mdi:cogs"
    optimistic: true
    restore_value: true #If you don't want to store the setting at ESP, set it to false.
    initial_value: "60.0" #Default mth1 Setting
    min_value: 10.0
    max_value: 600.0
    step: 5.0
    set_action:
      then:
        - uart.write:
            data: !lambda |-
              std::string th1st = "mth1=" + str_sprintf("%.0f",x) +"\r\n";
    name: LD1125H mth2 #mth2 is 2.8~8m Sensitivity.
    icon: "mdi:cogs"
    optimistic: true
    initial_value: "30" #Default mth2 Setting
    min_value: 5
    max_value: 300
    step: 5
    set_action:
      then:
        - uart.write:
            data: !lambda |-
              std::string th2st = "mth2=" + str_sprintf("%.0f",x) +"\r\n";
    name: LD1125H mth3 #mth3 is above 8m Sensitivity.
    icon: "mdi:cogs"
    optimistic: true
    initial_value: "20" #Default mth3 Setting
    min_value: 5
    max_value: 200
    step: 5
    set_action:
      then:
        - uart.write:
            data: !lambda |-
              std::string th3st = "mth3=" + str_sprintf("%.0f",x) +"\r\n";
    name: LD1125H rmax #rmax is max detection distance.
    icon: "mdi:cogs"
    optimistic: true
    initial_value: "8" #Default rmax Setting
    min_value: 0.4
    max_value: 12
    step: 0.2
    set_action:
      then:
        - uart.write:
            data: !lambda |-
              std::string rmaxst = "rmax=" + str_sprintf("%.1f",x) +"\r\n";
    name: LD1125H Clearence Time
    icon: "mdi:cogs"
    optimistic: true
    initial_value: "5" #LD1125H Mov/Occ > Clearence Time Here
    min_value: 0.5
    max_value: 20
    step: 0.5
    name: LD1125H Movement Time
    icon: "mdi:cogs"
    optimistic: true
    initial_value: "1" #LD1125H Mov > Occ Time Here
    min_value: 0.5
    max_value: 10
    step: 0.5
    icon: "mdi:signal-distance-variant"
    unit_of_measurement: "m"
    accuracy_decimals: 2
    filters:    # Use Fliter To Debounce
    - sliding_window_moving_average:
        window_size: 8
        send_every: 2
    - heartbeat: 0.2s
text_sensor:
  - platform: serial
    uart_id: LD1125H_UART_BUS
    name: LD1125H UART Text
    icon: "mdi:format-text"
    internal: False #If Don't Want to See UART Receive Data, Set To True
    on_value:
      lambda: |-
        if (id(LD1125H_UART_Text).state.substr(0,3) == "occ") {
          id(LD1125H_Distance).publish_state(atof(id(LD1125H_UART_Text).state.substr(9).c_str()));
          if ((time(NULL)-id(LD1125H_Last_Mov_Time))>id(LD1125H_Mov_Time).state) {
            id(LD1125H_Occupancy).publish_state("Occupancy");
            if (id(LD1125H_MovOcc_Binary).state == false) {
              id(LD1125H_MovOcc_Binary).publish_state(true);
          id(LD1125H_Last_Time) = time(NULL);
          if (id(LD1125H_Clearence_Status) == true) {
            id(LD1125H_Clearence_Status) = false;
        else if (id(LD1125H_UART_Text).state.substr(0,3) == "mov") {
          id(LD1125H_Occupancy).publish_state("Movement");
          if (id(LD1125H_Mov_Binary).state == false) {
            id(LD1125H_Mov_Binary).publish_state(true);
          id(LD1125H_Last_Mov_Time) = time(NULL);
    name: LD1125H Occupancy Status
    icon: "mdi:motion-sensor"
binary_sensor:
    name: LD1125H Occupancy or Movement
    device_class: occupancy
    device_class: motion
@Hilink-Lucia Any advice?
Not sure what issue you are having, but I was not getting a response from the sensors in HA as they were all showing as ‘Unknown’. It seems I had to reverse the connections of the URX/UTX pins as opposed to what’s listed in the diagram linked below.
