This is what I got from my logs from ESPHome Web
18:51:38][D][api:122]: Accepted 192.168.1.162
[18:51:38][W][component:182]: Component api cleared Warning flag
[18:51:38][D][api.connection:1529]: Home Assistant 2025.5.3 (192.168.1.162): Connected successfully
[18:52:18][I][safe_mode:041]: Boot seems successful; resetting boot loop counter
[18:52:19][D][esp32.preferences:114]: Saving 1 preferences to flash...
[18:52:19][D][esp32.preferences:142]: Saving 1 preferences to flash: 0 cached, 1 written, 0 failed
I would start with a clean minimal YAML without the mhz sensor. Your problem appears to be happening during the compile. Using a new a device name and YAML file will get you to a clean state. It is possible things are really messed up and this might help show you exactly what is wrong.
There is a common misconception that you MUST run the esphome compiler on your HA machine. This is not true. Of course, you can, but many people believe in keeping the two separate.
It sounds like your installation of esphome and/or its dependencies is corrupted. Your HA dashboard is likely a separate issue.
Most definitely the HA dashboard is something else. It’s just stack upon the other issues I have run into.
There are great YT and website on installation of MH-Z19/ESP32 and integration into HA. However there aren’t many on when you run into issues. Even using ChatGPT to find a solution hasn’t really resolved the issue I’m having.
I have uninstalled ESPhome several times, cleared cache, manually installed .bin via ESPHome Web .
I’m not running ESPHome compiler on my HA machine.
esphome is a Python program I install it using the following:
pip install pipx
pipx install esphome
pip is the standard Python package installer
pipx is a tool that allows installing other Python tools into their own virtual environment.
esphome will install platform. io platform.io has it’s own cache of tools and libraries that it installs. I suspect that something that it downloaded got corrupted.
I uninstall it from Settings>Add-ons. The Cache I clear is from ESPHome in HA clear install files. Then reboot HA. For the ESP32 board I reset it from ESPHome Web.
Do I use Terminal in HA to install PIP? That’s where I lack the knowledge.
that statement is inconsistent with the statement in the previous post
As far as I understand things that means you are installing and running esphome on your HA machine. You might be using a different computer to access it, but the compile and its dependencies are on the HA computer.
You can and I do install and run esphome on a completely different computer from where I run HA. HA is pushing people to use HAOS because it makes it easier to support things since they then know how things are installed. It does make some things easier. I don’t know if the commands you ran will actually clean up a corrupt platform.io install. It seems not.
I don’t know. I also don’t know if it does or does not uninstall platform.io or if platform.io uninstalls its dependencies all the time. On my install, I know where platform.io installs its dependencies so I know where to delete things safely, so that it will install them again. There probably is a platformio way to get it to reinstall its dependencies.
esphome hides most of platformio from you. This is great when things work, but makes it significantly harder when things stop working. I have used platformio independently so have some understanding of what it is doing and how to get it to do what I want, but it is still challenging when things stop working.
/data/cache/platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/lib/no-rtti/crt0.o: file not recognized: file format not recognized
collect2: error: ld returned 1 exit status
*** [.pioenvs/co2-monitor/firmware.elf] Error 1
========================= [FAILED] Took 217.59 seconds =========================
