I installed MQTT via the “add-on” and followed the directions. I previously tested with a public MQTT broker as suggested and I got about 25 devices. Everything in the logs look “good/green” so I’m not sure what’s up. If I got 25 or so devices before with the public broker, why don’t I get them now?
Also, trying to get Frigate up but it always says unable to connect.
Can you please share the options and the network settings from the configuration page of the add-on?
And what kind of HA installation do you have? HA OS oder Docker / Supervised?
I only saw them for a minute. There was a Tasmoda? But basically, I am trying to get Frigate up and running. It says it can’t connect so I’m assuming it’s an MQTT broker issue. Maybe I’m going down the wrong rabbit hole?
Totally - yes. Still learning the difference of ‘add-on’ and ‘add-on’. Sometimes people use this term when they mean a repository instead of an integration. It’s all becoming clearer. Thanks for the follow-up. I got Frigate up and running!
