th4h4x
(Peter)
1
Hey there,
Using android companion app…I can’t get a local snapshot to display in my notification.
This works :
- action: notify.mobile_app_sm_s916w
message: TEST
image: https://www.home-assistant.io/images/default-social.png
But this doesn’t :
message: TEST
image: "/media/local/snapshot.jpg"
And I do have this in my configuration.yaml
default_config:
homeassistant:
media_dirs:
local: /media
allowlist_external_dirs:
- "/config/media/"
The snapshot is indeed in the right directory…
What’s wrong ? I’m sure it has to do with accessing the snapshot…
woempiej
(Woempiej)
2
I do not use the below in my configutation.yaml
homeassistant:
media_dirs:
local: /media
I am only using:
homeassistant:
- /config/www/tmp/
and for notification data image (without the “”):
image: /local/tmp/snapshot.jpg
Maybe with this works, remove the /config and the “” from the image url
message: TEST
image: /local/media/snapshot.jpg
th4h4x
(Peter)
3
Thank you, made both changes, but still not getting an image in the notification.
woempiej
(Woempiej)
4
your .jpg file needs to be in the /www/tmp/ folder with this setup.
Then the image URL in your notification should be image: /local/tmp/snapshot.jpg
