Can't get "Total_Daily_Energy working
Had this working with ESP32 and IAN219, but for some reason I can’t get it working with ESP8266 and IAN3221. I’m currently only using Channel 2 all readings are good in the sensors till I try to add the Total_Daily_Energy configuration. I can post the ESP32 IAN219 configuration if necessary
esp8266:
  board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
  password: "2658a10a85f927998ff66c8859186d5b"
wifi:
  ssid: "XXXXXX"
  password: "XXXXXXX"
# Optional manual IP
  manual_ip:
    static_ip: 192.168.1.96
    gateway: 192.168.1.1
    subnet: 255.255.255.0
  ap:
    ssid: "Solar-Panels-3221"
    password: "Y9fH0IPkz5U4"
captive_portal:
# Example configuration entry
i2c:
  sda: GPIO 4
  scl: GPIO 5
  scan: true
  - platform: ina3221
    address: 0x40
    channel_1:
      shunt_resistance: 0.0025 ohm
      current:
        name: "INA3221 Channel 1 Current"
      power:
        name: "INA3221 Channel 1 Power"
      bus_voltage:
        name: "INA3221 Channel 1 Bus Voltage"
      shunt_voltage:
        name: "INA3221 Channel 1 Shunt Voltage"
    channel_2:
      shunt_resistance: 0.0030 ohm
      current:
        name: "INA3221 Channel 2 Current"
      power:
      bus_voltage:
        name: "INA3221 Channel 2 Bus Voltage"
        filters:
          multiply: 1.0
      shunt_voltage:
        name: "INA3221 Channel 2 Shunt Voltage"
    channel_3:
      shunt_resistance: 0.0049 ohm
      current:
        name: "INA3221 Channel 3 Current"
      power:
        name: "INA3221 Channel 3 Power"
      bus_voltage:
        name: "INA3221 Channel 3 Bus Voltage"
      shunt_voltage:
        name: "INA3221 Channel 3 Shunt Voltage"
    update_interval: 30s
  - platform: total_daily_energy
    name: "Total Daily Energy"
    power_id: INA3221_Channel_2_Power
  # The power sensor to convert, can be any power sensor
  - platform: ina3221
    power:
      filters:
        # Multiplication factor from W to kW is 0.001
        - multiply: 0.001
      unit_of_measurement: kWh
# Enable time component to reset energy at midnight
time:
  - platform: sntp
Please post your code properly, three backticks before and after ```
Sorry about that.
Resolved thanks
what was the fix?
