I bought a few of these units a while back and just can’t figure out how to use them. I think I have the esphome config correct because the LED on the sensor board changes to rapid flashing from solid when I flash the config. But I never get any readings. My boards do not have any area where it looks like I should put a resistor. I have swapped TX and RX just to make sure I didn’t have it backwards Are these just junk boards?
[09:02:16.675][D][ultrasonic.sensor:035]: ‘Oil Tank Level’ - Distance measurement timed out!
[09:02:16.675][D][sensor:133]: ‘Oil Tank Level’: Sending state nan m with 2 decimals of accuracy
I think it is on 3.3v. This is just a generic ESP32 from aliexpress.
So I did confirm it is on 5v. I ordered resistors and a soldering iron. I am having zero luck getting the solder to stick. I have never had any success soldering anything electrical. Is there a solution that does not involve soldering? Do I need a new board? The sensor itself is already epoxied in so it has to be compatible with that.
