I’ve been trying and trying to no avail to get this Controller configured. Here’s some screenshots and my log.
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/config.sh
[14:52:25] INFO: Both 'network_key' and 's0_legacy_key' are set and match. All ok.
[14:52:32] INFO: Soft-reset set to automatic
[14:52:32] INFO: Virtual Machine detected, disabling soft-reset
cont-init: info: /etc/cont-init.d/config.sh exited 0
cont-init: info: running /etc/cont-init.d/structure.sh
cont-init: info: /etc/cont-init.d/structure.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun zwave_js (no readiness notification)
s6-rc: info: service legacy-services successfully started
[14:52:43] INFO: Successfully send discovery information to Home Assistant.
2024-08-20T21:52:46.828Z DRIVER ███████╗ ██╗ ██╗ █████╗ ██╗ ██╗ ███████╗ ██╗ ███████╗
2024-08-20T21:52:46.847Z DRIVER version 12.11.2
2024-08-20T21:52:46.851Z DRIVER
2024-08-20T21:52:46.853Z DRIVER starting driver...
2024-08-20T21:52:46.860Z DRIVER opening serial port /dev/ttyS3
Logging to file:
/config/zwave_2024-08-20.log
2024-08-20T21:52:55.982Z DRIVER Failed to open the serial port: Error: I/O error setting custom baud rate of 1
15200
2024-08-20T21:52:55.990Z DRIVER destroying driver instance...
Unable to start driver ZWaveError: Failed to open the serial port: Error: I/O error setting custom baud rate of 115200 (ZW0100)
at Driver.openSerialport (/usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:1336:9)
at Immediate.<anonymous> (/usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:1171:5) {
code: 100,
context: undefined,
transactionSource: undefined
[21:52:56] WARNING: Halt add-on
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
[15:34:03] INFO: Both 'network_key' and 's0_legacy_key' are set and match. All ok.
[15:34:10] INFO: Soft-reset set to automatic
[15:34:10] INFO: Virtual Machine detected, disabling soft-reset
[15:34:19] INFO: Successfully send discovery information to Home Assistant.
2024-08-20T22:34:23.346Z DRIVER ███████╗ ██╗ ██╗ █████╗ ██╗ ██╗ ███████╗ ██╗ ███████╗
2024-08-20T22:34:23.358Z DRIVER version 12.11.2
2024-08-20T22:34:23.361Z DRIVER
2024-08-20T22:34:23.362Z DRIVER starting driver...
2024-08-20T22:34:23.364Z DRIVER opening serial port /dev/ttyS3
Logging to file:
2024-08-20T22:34:32.465Z DRIVER Failed to open the serial port: Error: I/O error setting custom baud rate of 1
15200
2024-08-20T22:34:32.474Z DRIVER destroying driver instance...
code: 100,
context: undefined,
[22:34:33] WARNING: Halt add-on
