Hi there,
i tried to install 0.96.1 , i’m on 0.95.4. It didn’t work.
Than i got the message, that 0.96.2 ist available.
I also tried to install on the Webinterface with the “update button”.
It didn’t work. The error is called @ System log:
19-07-20 19:07:23 INFO (MainThread) [hassio.homeassistant] Update Home Assistant to version 0.96.2
19-07-20 19:07:23 INFO (SyncWorker_6) [hassio.docker.interface] Update image homeassistant/raspberrypi3-homeassistant:0.95.4 to homeassistant/raspberrypi3-homeassistant:0.96.2
19-07-20 19:07:23 INFO (SyncWorker_6) [hassio.docker.interface] Pull image homeassistant/raspberrypi3-homeassistant tag 0.96.2.
19-07-20 19:07:25 ERROR (SyncWorker_6) [hassio.docker.interface] Can’t install homeassistant/raspberrypi3-homeassistant:0.96.2 -> 500 Server Error: Internal Server Error (“readlink /mnt/data/docker/overlay2/l: invalid argument”).
19-07-20 19:07:25 WARNING (MainThread) [hassio.homeassistant] Update Home Assistant image fails
is this error on my Raspberry Pi ?
What can I do?
Thank you for the help
