Can't install homeassistant/armhf-addon-configurator
Hi all,
I am trying to run the latest Hass.io on RPi B rev1.
I have successfuly installed the SSH addon and am able to SSH into the box.
I would like to install the official Configurator app and MariaDB but get the following errors:
19-01-04 20:27:28 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
19-01-04 20:28:52 ERROR (SyncWorker_0) [hassio.docker.interface] Can't install homeassistant/armhf-addon-configurator:2 -> 404 Client Error: Not Found ("no such image: homeassistant/armhf-addon-configurator:2: No such image: homeassistant/armhf-addon-configurator:2").
19-01-04 20:30:43 INFO (SyncWorker_0) [hassio.docker.interface] Pull image homeassistant/armhf-addon-configurator tag 2.
19-01-04 20:32:01 ERROR (SyncWorker_0) [hassio.docker.interface] Can't install homeassistant/armhf-addon-configurator:2 -> 404 Client Error: Not Found ("no such image: homeassistant/armhf-addon-configurator:2: No such image: homeassistant/armhf-addon-configurator:2").
19-01-04 20:46:41 INFO (MainThread) [hassio.addons.addon] Create Home Assistant add-on data folder /data/addons/data/core_mariadb
19-01-04 20:46:41 INFO (SyncWorker_0) [hassio.docker.interface] Pull image homeassistant/armhf-addon-mariadb tag 0.2.
19-01-04 20:47:55 ERROR (SyncWorker_0) [hassio.docker.interface] Can't install homeassistant/armhf-addon-mariadb:0.2 -> 404 Client Error: Not Found ("no such image: homeassistant/armhf-addon-mariadb:0.2: No such image: homeassistant/armhf-addon-mariadb:0.2").
HDD space:
Filesystem                Size      Used Available Use% Mounted on
overlay                  13.8G      1.4G     11.7G  11% /
tmpfs                    64.0M         0     64.0M   0% /dev
tmpfs                    89.3M         0     89.3M   0% /sys/fs/cgroup
/dev/root                78.4M     78.4M         0 100% /dev/init
/dev/mmcblk0p8           13.8G      1.4G     11.7G  11% /data
/dev/mmcblk0p8           13.8G      1.4G     11.7G  11% /config
/dev/mmcblk0p8           13.8G      1.4G     11.7G  11% /ssl
/dev/mmcblk0p8           13.8G      1.4G     11.7G  11% /addons
/dev/mmcblk0p8           13.8G      1.4G     11.7G  11% /backup
/dev/mmcblk0p8           13.8G      1.4G     11.7G  11% /share
/dev/mmcblk0p8           13.8G      1.4G     11.7G  11% /etc/resolv.conf
/dev/mmcblk0p8           13.8G      1.4G     11.7G  11% /etc/hostname
/dev/mmcblk0p8           13.8G      1.4G     11.7G  11% /etc/hosts
shm                      64.0M         0     64.0M   0% /dev/shm
tmpfs                    64.0M         0     64.0M   0% /proc/keys
tmpfs                    64.0M         0     64.0M   0% /proc/latency_stats
tmpfs                    64.0M         0     64.0M   0% /proc/timer_list
tmpfs                    64.0M         0     64.0M   0% /proc/sched_debug
tmpfs                    89.3M         0     89.3M   0% /sys/firmware
RAM seems to be taken up:
core-ssh:/config# free -m
             total       used       free     shared    buffers     cached
Mem:           178        165         12          0          8         34
-/+ buffers/cache:        122         55
Swap:           35         35          0
I would like to increase size of the swap file.
Is that possible?
Or is there other ways to installing the addons?
The emphasis of the error message is: 404 Client Error: Not Found ("no such image: homeassistant/armhf-addon-configurator:2: No such image: homeassistant/armhf-addon-configurator:2").
This indicates, that there was a problem with the server where the addons are downloaded from. You should wait a bit and then try again.
I have the same problem:
19-01-20 16:31:00 ERROR (SyncWorker_3) [hassio.docker.interface] Can't install homeassistant/armhf-addon-google_assistant:2.1 -> 404 Client Error: Not Found ("no such image: homeassistant/armhf-addon-google_assistant:2.1: No such image: homeassistant/armhf-addon-google_assistant:2.1").
Me too. Has any one confirmed this is server related? Is there any way around it?
I solved my situation by connecting to the box via SSH and editing the configurations i needed using the built in text editor.
I’m having the same issue, just setup Hass.IO and can’t install Configurator or Samba. I get this error:
manifest for homeassistant/armv7-addon-configurator:2 not found
When I check the docker location, it looks like the tag should be 2.1, is there any way to update that manually?
