Hi all,
Since a couple of days I can’t install any add-on update or restore any backup. When I try to restore a backup it gives me this:
I suspect problems began after installing supervisor update 2023.01.1. In the logs (https://home.xxxx.xxx/hassio/system) nothing related is found (only a lot of “WARNING (MainThread) [supervisor.api.ingress] No valid ingress session” warnings, but does not seem to related to me). I’ve have a pendig update for ESPHome, but this can’t be installed because of the same error. I tried to reboot, did all latest apt-get updates, doesn’t make any difference. Even an “ha su repair” on the CLI gives the same error. I’m running on Ubuntu 16.05. I don’t have a warning about the system being unhealthy.
Any ideas?
Thanks in advace.
