I’ve come here because i’ve some trouble with my todo lists.
For the context i’m running HA on 1 PC, 1 tablet and 2 smartphone (wife and i).
I don’t even know when (days or weeks ago) but sometimes i can’t modify anything on my todo, got this error :“Failed to perform the action todo/update_item. must contain at least one of entity_id, device_id, area_id, floor_id, label_id.”
The fact is i don’t know how to regain control of this, i’ve cleanup all of my HACS integration or add-on i don’t need, and i don’t even know what is the cause of this trouble.
If i reboot HA in safe mod, everything is ok.
When i looked at the log, i see nothing wrong, even if i enable debug mode for the todo integration, nothing come in the log.
Here is my list of integration and add-on, if you can enlight me on what cause me this.
When i add, remove or update from the developper tool, it works
When i try to use the sidecard “To-do lists” (provide by the official integration) i can read the data, but i can’t modify them
Did this work before or did it stop working at a specific point in time?
I can only think of these two relevant things:
Have you tried to clear all device caches?
What custom integrations are you running that could interfere here? (This is probably why things work in safe mode, since safe mode disables all custom integrations.)
Unfortunaly i don’t know, i only realise when my wife try to use it
Yes
For testing i’ve already disabled all the custom integration , but nothing came better !
The safemod says it’s disable any frontend module, can it be the problem?
I download the custom sidebar once but never use is yet.
I think i’m gonna do a fresh install of home assistant, maybe is juste a misconfiguration of something that cause my trouble
