Can't mount network storage
I am using my NAS as a backup storage.
This worked fine until I upgraded to these versions:
This is the error from the host log:
2025-04-08 19:29:41.022 homeassistant.local systemd[1]: Mounting Supervisor cifs mount: NAS...
2025-04-08 19:29:41.036 homeassistant.local kernel: CIFS: Attempting to mount //192.168.1.15/Misc
2025-04-08 19:29:51.381 homeassistant.local mount[3866]: mount error(115): Operation now in progress
2025-04-08 19:29:51.381 homeassistant.local mount[3866]: Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
2025-04-08 19:29:51.385 homeassistant.local kernel: CIFS: VFS: Error connecting to socket. Aborting operation.
2025-04-08 19:29:51.385 homeassistant.local kernel: CIFS: VFS: cifs_mount failed w/return code = -115
2025-04-08 19:29:51.386 homeassistant.local systemd[1]: mnt-data-supervisor-mounts-NAS.mount: Mount process exited, code=exited, status=32/n/a
2025-04-08 19:29:51.387 homeassistant.local systemd[1]: mnt-data-supervisor-mounts-NAS.mount: Failed with result 'exit-code'.
2025-04-08 19:29:51.389 homeassistant.local systemd[1]: Failed to mount Supervisor cifs mount: NAS.
This is my system information:
System Information
version core-2025.4.1
installation_type Home Assistant OS
dev false
home assistant OS true
docker true
user root
virtualenv false
python_version 3.13.2
os_name Linux
os_version 6.6.74-haos-raspi
arch aarch64
timezone America/New_York
config_dir /config
Home Assistant Cloud
logged_in false
can_reach_cert_server ok
can_reach_cloud_auth ok
can_reach_cloud ok
Home Assistant Supervisor
host_os Home Assistant OS 15.1
update_channel stable
supervisor_version supervisor-2025.03.4
agent_version 1.7.2
docker_version 28.0.4
disk_total 57.8 GB
disk_used 7.4 GB
healthy true
supported true
host_connectivity true
supervisor_connectivity true
ntp_synchronized true
virtualization
board rpi4-64
supervisor_api ok
version_api ok
installed_addons Z-Wave JS (0.10.0), Tailscale (0.25.0), Studio Code Server (5.15.0), File editor (5.8.0), Terminal & SSH (9.16.0)
Dashboards
dashboards 4
resources 0
views 4
mode storage
Network Configuration
adapters lo (disabled), end0 (enabled, default, auto), home assistant OS (disabled), docker0 (disabled), vethbc8018d (disabled), veth38c3f96 (disabled), vetha7da88a (disabled), veth89bb246 (disabled), veth2929094 (disabled), vethf9776de (disabled), veth88b9598 (disabled), vethdae1e35 (disabled)
ipv4_addresses lo (127.0.0.1/8), end0 (192.168.1.28/24), home assistant OS (172.30.32.1/23), docker0 (172.30.232.1/23), vethbc8018d (), veth38c3f96 (), vetha7da88a (), veth89bb246 (), veth2929094 (), vethf9776de (), veth88b9598 (), vethdae1e35 ()
ipv6_addresses lo (::1/128), end0 (fddb:96c9:72c0:ed9a:16f4:29e9:b022:c68c/64, fe80::81c6:dd7c:71e9:a51d/64), home assistant OS (fe80::6ca2:45ff:fed9:d9f0/64), docker0 (fe80::f0a4:6ff:fef6:9634/64), vethbc8018d (fe80::40e9:46ff:fe94:5a5c/64), veth38c3f96 (fe80::78ea:27ff:fe30:d079/64), vetha7da88a (fe80::50c2:c5ff:fe81:4131/64), veth89bb246 (fe80::d4ac:60ff:fe01:f300/64), veth2929094 (fe80::4c49:7eff:feaf:5731/64), vethf9776de (fe80::44ab:cbff:feae:dcd1/64), veth88b9598 (fe80::607f:fcff:fe66:cf4/64), vethdae1e35 (fe80::3c57:29ff:fe3c:ce2d/64)
announce_addresses 192.168.1.28, fddb:96c9:72c0:ed9a:16f4:29e9:b022:c68c, fe80::81c6:dd7c:71e9:a51d
Recorder
oldest_recorder_run April 1, 2025 at 2:07 PM
current_recorder_run April 8, 2025 at 2:46 PM
estimated_db_size 43.43 MiB
database_engine sqlite
database_version 3.48.0
