Cant restart Home Assistant
Since a couple of versions back (0.114?) I cant restart Home Assistant from the GUI.
HA stalls/hangs and the log says:
2020-10-15 20:21:31 ERROR (MainThread) [homeassistant.components.ipp] Error fetching ipp data: Invalid response from API: Error occurred while communicating with IPP server.
2020-10-15 20:21:31 WARNING (MainThread) [homeassistant.config_entries] Config entry for ipp not ready yet. Retrying in 80 seconds
2020-10-15 20:21:42 ERROR (Thread-38) [root] Uncaught thread exception
File “/usr/local/lib/python3.8/threading.py”, line 932, in _bootstrap_inner
self.run()
File “/usr/local/lib/python3.8/threading.py”, line 870, in run
self._target(*self._args, **self._kwargs)
File “/usr/local/lib/python3.8/site-packages/xiaomi_gateway/init.py”, line 180, in _listen_to_msg
data, (ip_add, _) = self._mcastsocket.recvfrom(SOCKET_BUFSIZE)
OSError: [Errno 9] Bad file descriptor
I run in Docker, so I can restart it by restarting the container.
Any suggestions?
Same here. Just updated to 116.3 and for first time it restarted.
Didnt help me unfortunatly
I just increase buffer size in init.py to 8192, then all things go to normal.
