Good evening,
I wrote these two scripts, one call the other 3 times and even if they are set in parallel mode, actually they wait for the previous script delay to end before starting. Any clue ?
thank you
close_half_roller_shutter:
alias: close_half_roller_shutter
mode: "parallel"
fields:
device_id:
description: "the device id"
example: "newkaku_XXXX"
sequence:
- service: rflink.send_command
data_template:
command: "off"
device_id: "{{device_id}}"
- delay: "{{ states('variable.roller_shutter_timer_' + device_id) | int }}"
data_template:
command: "off"
and
close_all_half_roller_shutter:
alias: close_all_half_roller_shutter
mode: "single"
sequence:
- service: script.close_half_roller_shutter
device_id: "newkaku_XXXX"
device_id: "newkaku_YYYY"
device_id: "newkaku_ZZZZ"
