I’ve installed hassbian on an rpi and set up smb. On any Android device I can see the front end and can alter and save the config files through the smb share.
On my Mac and a Windows 10 PC, I can SSH into it via terminal/putty with no problems however, THAT’S ALL!
Trying to load the front end in any browser does nothing other than eventually timing out. I can see the smb share on both devices and it takes the username and password OK but then all that happens is a permanent beachball on the Mac and a spinning blue circle in Windows which requires force quitting/end task to regain control.
Hi, thanks for the reply. Yes, it’s fresh bar setting up RF switches via an RM Pro and then setting up samba using that youtube guide though using the correct address for a hassbian install.
No errors in the log, Mac and PC on same network though hard wired same as the Pi, Android devices are wireless.
When SSHing I use the IP on all devices. Changed the name in etc/hostnames to match that in etc/hosts today which sped up SSH sessions dramatically and stopped the it moaning about resolving host but smb and front end just the same.
Oooh…a development, your question about the network made me think. The device on wireless works, the others are by wire, so just tried forcing the the Mac onto wireless and …hey presto, frontend came up and I can see and edit the config over samba.
