Can't seem to find a way to send music to ZONE2 on my new Denon AVC-X3800H
So I recently upgrade from AVR-X1000 to AVR-X3800H. This now gives me the chance to connect speakers in the garden to the ZONE2 on the receiver.
Of course, I want to be able to send music to this zone independent from the MAIN zone.
I can't seem to find a way to make this work.
  1. my old denon got discovered in dlna integration, however the new one isn't being discovered this way (it has received the same IP, if that matters. it's in a different vlan as HA)
  2. The new Denon has HEOS built in, however the Heos integration doesn't see the different zones.
  3. the Denon AVR integration does see the MAIN and ZONE2 zones, and I can control the device as in turn on/of and volume and so on. But I can't seem to send for example the command to play music on either of them. (tested in Music Assistant and via Media, playercommand failed)
  4. I tried to create 2 universal media players following the configure found here, but then they both seemed to just send music to the Main zone.
I'm a bit lost here...any help would be appreciated
UPDATE 1:
I was able to set up DLNA by capturing the SSDP packets and the getting the URL and configure manually. However, this resulted only in the box being visible, not the 2 zones separately.
UPDATE 2:
I found a solution for the favoriote Radio station buttons in my dashboard, by updating my old scripts to check a drop down and then turn on the respective zones using the Denon AVR integration and then playing the Radio via the Heos integration
sequence:
  - choose:
      - conditions:
          - condition: state
            entity_id: input_select.denon_player
            state:
              - Living Room
        sequence:
          - action: media_player.turn_on
            metadata: {}
              entity_id: media_player.living_room
            data: {}
      - conditions:
          - condition: state
            state:
              - Garden
        sequence:
            metadata: {}
              entity_id: media_player.backyard
            data: {}
      - conditions:
          - condition: state
            state:
              - All
        sequence:
            metadata: {}
              entity_id:
                - media_player.backyard
                - media_player.living_room
            data: {}
  - action: media_player.play_media
      media:
        media_content_id: media-source://radio_browser/957af496-47ae-4d2e-845a-bcc7e562c158
        media_content_type: audio/mpeg
        metadata:
          title: Studio Brussel UNTZ
          thumbnail: >-
            https://www.vrt.be/content/dam/vrtvideo/branding/logos/stubru-untz/v3/color.svg
          media_class: music
          children_media_class: null
          navigateIds:
            - media_content_type: app
            - media_content_type: music
              media_content_id: media-source://radio_browser/country/BE
      entity_id: media_player.home_theater_heos
alias: Play StuBru Untz
description: ""
icon: mdi:radio
STILL OPEN:
How can I achieve the same with Music Assistant without having to go and manually turn on or off certain zone?
as per number 4, Itried using these universal media players:
media_player:
  - platform: universal
    name: Denon Living Room
    unique_id: denon_universal_living_room
    device_class: receiver
    children:
      - media_player.living_room       # Denon AVR Integration entity
      - media_player.home_theater_heos  # Denon HEOS Integration entity
    browse_media_entity: media_player.home_theater_heos
    commands:
      turn_off:
        action: media_player.turn_off
      turn_on:
      volume_up:
        action: media_player.volume_up
      volume_down:
        action: media_player.volume_down
      select_sound_mode:
        action: media_player.select_sound_mode
          sound_mode: "{{ sound_mode }}"
    attributes:
      sound_mode: media_player.living_room|sound_mode
      sound_mode_raw: media_player.living_room|sound_mode_raw
      sound_mode_list: media_player.living_room|sound_mode_list
    unique_id: denon_universal_garden
    children:
      - media_player.backyard       # Denon AVR Integration entity
    commands:
      turn_off:
      turn_on:
      volume_up:
      volume_down:
      select_sound_mode:
    attributes:
      sound_mode: media_player.backyard|sound_mode
      sound_mode_raw: media_player.backyard|sound_mode_raw
      sound_mode_list: media_player.backyard|sound_mode_list
However they behave nowhere as expected:
Denon Living Room shows like this:
Denon Garden shows like this:
selecting the checkbox creates an error.
Selecting either of them just results in the MAIN zone playing, unless I go turn on the ZONE2 in the denon AVR integration.
Anyone suggestion to have a player in Music Assitant that can turn on the correct zone(s) when tryign to play a track ?
Are you asking about how to route data and commands between two network destinations you deliberately separated?
I am not.
I just mention that it's not being discovered by DLNA like it did do somehow with the previous one that was in the same VLAN and same IP even, the seperate network was never the problem before either.
by the way I actually found the way to add it on DLNA integration (using PCAPs taken on my firewall), but to no avail since it only recognizes the box and not the zones.
What I am asking is how can I send music directly to ZONE2 using HA.
In fact: I can send music to the box successfully using the Heos integration, but then it just send it to the MAIN zone, I ask if someone found a way to send to ZONE2 only
bump...still hoping to be able to play from music assistant directly
Maybe you do have VLAN configuration issues after all.
Dude, I don't have VLAN confiugration issues. I'm asking a question that is purely related to how certain mediaplayers function in HA. Maybe if you'd actually read all information in the post, you'd get that.
I got my network more dialed in than you could think. If you don't want to actually answer the question, then please refrain from commenting.
Did you manage to solve this? I'm running into the same trouble. I just want a simple, functional zone 2 media_player in home assistant and music assistant. But can't seem to get there....
