Hello
I read recommendations for Matter/Thread in this section.
I have HA OS working on Proxmox and SMLight SLZB-MR1 as OpenThread Border Router. I can see Nuki in the Matter devices with fdb3:a9d2:e7c3:1:b5ef:e6cb:7e05:bd76 ip adress. I can interview with the device. I can ping the lock from HA inside device settings ping command. HA OS has the fixed ipv4 adress set in the system network settings and ipv6 adresses are automatic as fd7e:f16f:c9e2:7c2d:592f:57f5:b26a:2cc5 and fe80::6776:d44d:a6b8:e826. Proxmox Host has a fixed ipv4 adress and no ipv6 adress set. When I send a open command after 30 sec I get the message Smart Lock Ultra became unknown. When I look at the Matter Server logs I see below messages.
2025-10-30 00:41:30.506 (MainThread) ERROR [matter_server.server] Error doing task: Task exception was never retrieved
File “/usr/local/lib/python3.12/site-packages/matter_server/server/client_handler.py”, line 213, in _run_handler
raise err
File “/usr/local/lib/python3.12/site-packages/matter_server/server/client_handler.py”, line 196, in _run_handler
result = await result
File “/usr/local/lib/python3.12/site-packages/matter_server/server/device_controller.py”, line 717, in send_device_command
return await self._chip_device_controller.send_command(
File “/usr/local/lib/python3.12/site-packages/matter_server/server/sdk.py”, line 308, in send_command
return await self._chip_controller.SendCommand(
File “/usr/local/lib/python3.12/site-packages/chip/ChipDeviceCtrl.py”, line 1552, in SendCommand
return await future
chip.interaction_model.InteractionModelError: InteractionModelError: Failure (0x1)
Please note that all devices are in the same ipv4 subnet. I can’t enable ipv6 over service provider. It is not supported. What can be the reason for the problem?
I also tried using sysctl -w net.ipv6.conf.vmbr0.accept_ra=2 && sysctl -w net.ipv6.conf.vmbr0.accept_ra_rt_info_max_plen=64 commands to Proxmox host, but then Nuki doesn’t receive ip adress anymore after restart of open thread borser and Matter server. Proxmox host receives an ip adress fd7e:f16f:c9e2:7c2d:eaff:1eff:fedd:bda1/64.
Regards
Gokalp
