I try to send negative values via the modbus service to victron but I get an error for negative values.
How can I solve this ?
Sent uint16 equivalent
I don’t think I understand your solution.
I have to send something like :
“address”: “2700”,
“value”: “10”,
“hub”: “victron”
As soon as I make the value negative I get the error.
I tried the same with the development service tab. Same error as soon as I send negative values.
How would your solution look like ?
Ok, but how do I send this hex number as a value in home assistant ?
65526 is a decimal number.
usually negative numbers in Modbus are requested as signed integers either int16 or int32 which have a range from -32768 to 32767 or -2,147,483,648 to +2,147,483,647 respectively. If using unsigned uint16 or uint32 the ranges are from 0 to 65535 and 0 to 4294967295.
This might be completely erroneous for your situation but just putting it out there.
thanks a lot, it works. I could just send the value 65525 and it sets it to -10
what do you send to your victron?
I would change adress 2700 to a negative value, but it doesn’t work.
this is my code:
- id: '1678392352553'
alias: Modbus schrijven
description: ''
- platform: state
entity_id:
- input_number.instelwatt
condition: []
- service: modbus.write_register
hub: victron
slave: 100
address: 2700
value: '{{ states(''input_number.instelwatt'') | int }}'
when instelwatt is above zero it works, but not negative
for negative values send a value of 65535 - input_number.instelwatt
example -1000 watt would be a value of 64535
