Can't setup/start SSL/TLS. Halts HASS in it's tracks
I’ve been searching for an answer to my problem but it seems all I can find is the problem but no solution.
I’ve got HA set up and running and I want to make it outward facing so I can do stuff while I’m away. Every time that I enable SSL it completely stops HA from starting,
[homeassistant.bootstrap] Component http failed to setup
further more I get an error for the key itself.
[homeassistant.bootstrap] Invalid config for [http]: not a file for dictionary value @ data[‘http’][‘ssl_key’]
I originally thought it was just the forwarder I was using so I switched to duckdns and followed all the how-to’s and faqs but still no go. Would really like to get this working.
running latest (i think) on a rpi3
You can get the version number from the little i on the left menu, under Developer Tools.
As for the error, please post that section of the configuration file, remembering to use the code tags (looks like </> in the text editor bar) so that the formatting isn’t lost. I suspect, from the error, a typo in ssl_key.
here’s the section from config
http:
server_port: 8123
api_password: !secret api_password
#base_url: myurl
#ssl_certificate: !secret secret_ssl_cert
#ssl_key: !secret secret_ssl_key
version 0.38.2
You forgot the formatting, so we can’t tell if the problem is because of the wrong number of spaces, etc.
http:
  server_port: 8123
  #base_url: myurl
I wonder if the issue is that it’s still parsing the !secret lines, and that’s causing issues. What if you simply delete those instead?
If I take those out how do I specify the ssl key and certs?
Are the hash tags actually in your config file? If so your commenting out those lines, essentially “removing” them from the config.
no, they’re not in there.
trying to enable SSL and this breaks HASS
http:
  server_port: 8123
  base_url: myurl
this does not
http:
  server_port: 8123
  #base_url: myurl
I still have to have it running so I’ve just commented out the lines until I can figure out a solution
What are you using for ssl, letsencrypt?
yes. I didn’t want to deal with installing self-signed certs on devices. I’m using letsencrypt on another device (owncloud) with no issues.
I would start with double checking the path in your secret file, should be along the lines of
ssl_key: ‘/etc/letsencrypt/live/yourdomain.duckdns.org/privkey.pem’
if that looks good check permissions on everything sub the letsencrypt folder.
In the video below at the 8:48 mark @bruhautomation suggests setting permissions to 777.
path and permission isn’t an issue as I can get the same result by moving everything to the homeassistant directory and chown it to the ha user.
I ran into the same issue yesterday. My certificate expired a couple days ago and finally got to update it yesterday, but couldn’t get it to load up. I had to comment out all the SSL stuff out to get it to load. Thought it was something I did updating the certificate.
have you found a solution yet? It’s quite annoying not being able to ssl.
One option, which is how I’ve done it, is to use the likes of nginx in reverse proxy mode. I went with that so that I could require (SSL and) authentication from outside the house, but no authentication from inside.
I’ve tried that and it works to a degree. I can get HA to display the login screen. Unfortunately it stops at the login page and goes no further. I just get the spinning icon and a failed loging attempt. I can’t even find anything in the logs to figure out what the actual issue is.
Without your nginx config, we’re just guessing what you’re doing :wink:
For reference, here’s mine:
server {
	listen 443;
	server_name MYHOST;
	access_log /var/log/nginx/MYHOST.access.log;
	error_log /var/log/nginx/MYHOST.error.log debug;
	ssl on;
	ssl_certificate /etc/letsencrypt/live/MYHOST/fullchain.pem;
	ssl_certificate_key /etc/letsencrypt/live/MYHOST/privkey.pem;
	proxy_buffering off;
	location / {
		auth_basic "Restricted"; #For Basic Auth
		auth_basic_user_file /etc/nginx/.htpasswd; #For Basic Auth
		include conf.d/proxy.conf;
		proxy_pass http://localhost:8123;
		proxy_set_header Host $host;
		proxy_http_version 1.1;
		proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
		proxy_set_header Upgrade $http_upgrade;
		proxy_set_header Connection $connection_upgrade;
Then there’s the proxy.conf file:
proxy_redirect off;
proxy_set_header X-Real-IP $remote_addr;
client_max_body_size 10m;
client_body_buffer_size 128k;
proxy_connect_timeout 90;
proxy_send_timeout 90;
proxy_read_timeout 90;
proxy_buffers 32 4k;
I got it working finally!
I was using the conf from the site and nginx was throwing a fit about the HTTP{} section. a few ### and It’s up and running now. :schew!:
My biggest issue was that I’m already running a dns forwarder so I piggybacked on that to keep the number of services and certificates down and having to work that across 2 devices.
Still doesn’t fix the original problem but I’m fine with this method.
