Can't update Configurator
Hey guys,
i’ve problems updating the configurator to version 3.1.
currently im running verions 2.0.
the info says “This update is no longer compatible with your system.”
thank you in advance
The new version requires 0.91.3 or later of Home Assistant.
Thank you for your quick answer!
I’ve problems to update to verision 0.91.4 too.
currently im on version 0.90.1 and i get this error:
19-04-19 09:52:22 ERROR (SyncWorker_15) [hassio.docker.interface] Can't install homeassistant/raspberrypi3-homeassistant:0.91.4 -> 500 Server Error: Internal Server Error ("readlink /mnt/data/docker/overlay2/l: invalid argument"). 19-04-19 09:52:22 WARNING (MainThread) [hassio.homeassistant] Update Home Assistant image fails
Is your SD card full?
No, that’s the First i’ve looked!
I’ve 70% free
Although I have not solved my problem, but my HA is running again after a recovery! :smile:
