I tried to update HAOS 6.6 to 7.0
Its say: backup operation system… but then I see a error message (so fast you can’t even read it)
then it stop and there is nothing updated.
Also no error messages in log files…
HA 6.6 on a RPi4 on SSD
HA behind a cloud flare config.
28GB used space and still 78GB free space on SSD
There is a backup file of OS 238MB in size…
I did a Check Home Assistant configuration (add-on) and thats goes without errors.
So downloading new updates is working.
EDIT: The update of HA Supervisor is updated without errors to 2021.12.1
Same here. I’m running HA 6.6 on a RPi3 with SD card, 78% free space.
Partial backup created is 298,2 MB, then the update stops without an error in the log files.
Everything else works, also the updates to core-2021.12.0 and supervisor-2021.12.1 were no problem.
A complete backup created independently is 327.9 MB.
I’m not able to update from 6.6 to 7.0 either. I’ve tried it twice, and each time a backup of 6.6 is created, but no update is done. This is with an RPi4 and a 256GB SSD (less than 10% used).
Same problem here, raspberry pi 3 b with 128G of SSD and just 12% used. Make the partial backup and after a while a error message appear but is fast and I can’t read.
Strange, mine will not perform either update. Same basic symptoms. It performs the backup but then nothing happens. No errors in the logs just nothing. I am getting the same result when updating the core myself.
21-12-13 16:07:35 INFO (MainThread) [supervisor.jobs] 'BackupManager.do_backup_partial' blocked from execution, system is not running - CoreState.FREEZE
Seeing all these issues here and on github, maybe the update should be retracted until a fix is available? Glad I ran into this befiore I noticed there was an update.
same here, already tried some time before the core upgrade, since the HA OS upgrade is available for a bit longer. But no luck, not before, not now. I keep removing the HA OS 6.6 backups, as they are -for now- useless.
Some extra details, in case people want to find similarities:
Host Operating System
Home Assistant OS 6.6
Update Channel
beta
Supervisor Version
Docker Version
20.10.8
Disk Total
458.4 GB
Disk Used
25.1 GB
Healthy
true
Supported
true
Board
rpi4-64
Supervisor API
ok
Version API
ok
Installed Add-ons
Home Assistant Google Drive Backup (0.105.2), File editor (5.3.3), Glances (0.14.0), ESPHome (2021.12.0), NGINX Home Assistant SSL proxy (3.0.2), Let’s Encrypt (4.12.0), Samba share (9.5.1), Mosquitto broker (6.0.1), ZeroTier One (0.12.1), InfluxDB (4.3.0), Node-RED (9.2.0), Zigbee2mqtt (1.22.1-1), TasmoAdmin (0.16.0), Visual Studio Code (3.6.2), AppDaemon 4 (0.6.2), SSH & Web Terminal (9.1.1), SQLite Web (3.2.0)
I was very scared to keep trying. If something went wrong and system reboot with some break parts I was needed to build a new one (lucky always have backups of the config)
in fact, for my Raspi 4 config, there’s nothing in this update that would require/tempt me update (no new kernel, only update to UART & ethernet) but I rather not fall behind too much.
