19-08-13 03:59:37 INFO (MainThread) [hassio.homeassistant] Update Home Assistant to version 0.97.2
19-08-13 03:59:37 INFO (SyncWorker_5) [hassio.docker.interface] Update image homeassistant/qemux86-64-homeassistant:0.97.0 to homeassistant/qemux86-64-homeassistant:0.97.2
19-08-13 03:59:37 INFO (SyncWorker_5) [hassio.docker.interface] Pull image homeassistant/qemux86-64-homeassistant tag 0.97.2.
19-08-13 04:00:12 ERROR (SyncWorker_5) [hassio.docker.interface] Can’t install homeassistant/qemux86-64-homeassistant:0.97.2 -> 404 Client Error: Not Found (“no such image: homeassistant/qemux86-64-homeassistant:0.97.2: No such image: homeassistant/qemux86-64-homeassistant:0.97.2”).
19-08-13 04:00:12 WARNING (MainThread) [hassio.homeassistant] Update Home Assistant image fails
thanks
Ernst-Jan
Hi Al, i want update to 0.98.2. CAn some help me with this issu.
19-09-02 13:04:56 INFO (MainThread) [hassio.homeassistant] Update Home Assistant to version 0.98.2
19-09-02 13:04:56 INFO (SyncWorker_3) [hassio.docker.interface] Update image homeassistant/qemux86-64-homeassistant:0.98.1 to homeassistant/qemux86-64-homeassistant:0.98.2
19-09-02 13:04:56 INFO (SyncWorker_3) [hassio.docker.interface] Pull image homeassistant/qemux86-64-homeassistant tag 0.98.2.
19-09-02 13:04:58 INFO (SyncWorker_3) [hassio.docker.interface] Stop homeassistant application
19-09-02 13:05:58 INFO (SyncWorker_3) [hassio.docker.interface] Clean homeassistant application
19-09-02 13:06:00 INFO (SyncWorker_1) [hassio.docker.homeassistant] Start homeassistant homeassistant/qemux86-64-homeassistant with version 0.98.2
19-09-02 13:06:20 INFO (MainThread) [hassio.homeassistant] Home Assistant pip installation in progress
19-09-02 13:07:00 INFO (MainThread) [hassio.homeassistant] Home Assistant pip installation done
19-09-02 13:07:05 INFO (MainThread) [hassio.homeassistant] Home Assistant pip installation in progress
19-09-02 13:07:20 INFO (MainThread) [hassio.homeassistant] Home Assistant pip installation done
19-09-02 13:17:21 WARNING (MainThread) [hassio.homeassistant] Don’t wait anymore of Home Assistant startup!
19-09-02 13:17:21 CRITICAL (MainThread) [hassio.homeassistant] HomeAssistant update fails -> rollback!
19-09-02 13:17:21 INFO (MainThread) [hassio.homeassistant] Update Home Assistant to version 0.98.1
19-09-02 13:17:21 INFO (SyncWorker_9) [hassio.docker.interface] Update image homeassistant/qemux86-64-homeassistant:0.98.2 to homeassistant/qemux86-64-homeassistant:0.98.1
19-09-02 13:17:21 INFO (SyncWorker_9) [hassio.docker.interface] Pull image homeassistant/qemux86-64-homeassistant tag 0.98.1.
19-09-02 13:17:22 INFO (SyncWorker_9) [hassio.docker.interface] Stop homeassistant application
19-09-02 13:17:23 INFO (SyncWorker_9) [hassio.docker.interface] Clean homeassistant application
19-09-02 13:17:24 INFO (SyncWorker_2) [hassio.docker.homeassistant] Start homeassistant homeassistant/qemux86-64-homeassistant with version 0.98.1
19-09-02 13:17:29 INFO (MainThread) [hassio.homeassistant] Home Assistant pip installation in progress
19-09-02 13:18:04 INFO (MainThread) [hassio.homeassistant] Home Assistant pip installation done
19-09-02 13:18:09 INFO (MainThread) [hassio.homeassistant] Home Assistant pip installation in progress
19-09-02 13:18:24 INFO (MainThread) [hassio.homeassistant] Home Assistant pip installation done
19-09-02 13:19:09 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance
19-09-02 13:19:09 INFO (MainThread) [hassio.homeassistant] Successful run Home Assistant 0.98.1
19-09-02 13:19:09 INFO (SyncWorker_3) [hassio.docker.interface] Cleanup images: [‘homeassistant/qemux86-64-homeassistant:0.98.2’]
yep, same issue here. Refuses to install and backs out to 0.97.1. Tries 3 times now. No luck. But my problem is more serious i guess.
I get this in the log every time: “Update for media_player.volumio fails” and “urllib3.exceptions.ProtocolError: (‘Connection aborted.’, UnknownProtocol(‘HTTP/0.0’))”
19-08-13 18:28:08 INFO (SyncWorker_3) [hassio.docker.interface] Pull image homeassistant/qemux86-64-homeassistant tag 0.97.2.
19-08-13 18:31:05 ERROR (SyncWorker_3) [hassio.docker.interface] Can’t install homeassistant/qemux86-64-homeassistant:0.97.2 -> 404 Client Error: Not Found (“no such image: homeassistant/qemux86-64-homeassistant:0.97.2: No such image: homeassistant/qemux86-64-homeassistant:0.97.2”).
Problem exists for a few days now. Looks like one of the devs upped the new image and went on the plane to start his summer holiday.
Oh well. I just wait patiently for the next update. My guess is that once the dev comes back from his vacation, he’ll see his mistake and fixes it as soon as possible. Then we can download the update and enjoy it.
In my case, i didn’t have to do anything. Tried 3 times and all of the times Hass.io backed out automatically to the previous version, 0.97.1.
If you don’t have that, you’ll have to join the beta channel.
That would be great if I had a running hassio. I don’t have a previous install - this is brand new. I do not have a UI to select a beta channel. I have access to the supervisor docker container - and that’s about it.
oof. That means you have to download a complete image from the hass.io site and update it. Lucky for you it’s only one update now, as 0.97 is the latest official version.
EDIT: don’t forget to join the beta channel.
If I was using an edge device, I understand how I would do what you are asking. Using the docker method, I do not see doc on how to use a lower version.
I am still getting this error, but I have confirmed that I can see the image exists in docker hub and it’s been more than enough time to rule out a server load issue. I’m running Hassio in a Hyper-V VM on Windows 10.
I’m getting the exact same thing on Hassio in a VirtualBox VM on Windows 10. It is also happening for updating the Hassio supervisor too.
19-08-26 20:39:40 INFO (MainThread) [hassio.store.git] Update add-on https://github.com/danimtb/dasshio.git repository
19-08-26 20:39:40 INFO (MainThread) [hassio.store.git] Update add-on https://github.com/home-assistant/hassio-addons repository
19-08-26 20:39:40 INFO (MainThread) [hassio.store.git] Update add-on https://github.com/hassio-addons/repository repository
19-08-26 20:39:40 INFO (MainThread) [hassio.updater] Fetch update data from https://version.home-assistant.io/stable.json
19-08-26 20:39:41 INFO (MainThread) [hassio.store] Load add-ons from store: 60 all - 0 new - 0 remove
19-08-26 21:24:40 INFO (MainThread) [hassio.tasks] Found new Hass.io version
19-08-26 21:24:40 INFO (MainThread) [hassio.supervisor] Update Supervisor to version 184
19-08-26 21:24:40 INFO (SyncWorker_6) [hassio.docker.interface] Update image homeassistant/amd64-hassio-supervisor:183 to homeassistant/amd64-hassio-supervisor:184
19-08-26 21:24:40 INFO (SyncWorker_6) [hassio.docker.interface] Pull image homeassistant/amd64-hassio-supervisor tag 184.
19-08-26 21:24:50 ERROR (SyncWorker_6) [hassio.docker.interface] Can't install homeassistant/amd64-hassio-supervisor:184 -> 404 Client Error: Not Found ("no such image: homeassistant/amd64-hassio-supervisor:184: No such image: homeassistant/amd64-hassio-supervisor:184").
19-08-26 21:24:50 ERROR (MainThread) [hassio.supervisor] Update of Hass.io fails!
19-08-26 21:24:50 ERROR (MainThread) [asyncio] Task exception was never retrieved
future: <Task finished coro=<Tasks._update_supervisor() done, defined at /usr/src/hassio/hassio/tasks.py:121> exception=SupervisorUpdateError()>
File "/usr/src/hassio/hassio/tasks.py", line 132, in _update_supervisor
await self.sys_supervisor.update()
File "/usr/src/hassio/hassio/supervisor.py", line 115, in update
raise SupervisorUpdateError() from None
hassio.exceptions.SupervisorUpdateError
19-08-26 21:49:34 INFO (MainThread) [hassio.supervisor] Update Supervisor to version 184
19-08-26 21:49:34 INFO (SyncWorker_7) [hassio.docker.interface] Update image homeassistant/amd64-hassio-supervisor:183 to homeassistant/amd64-hassio-supervisor:184
19-08-26 21:49:34 INFO (SyncWorker_7) [hassio.docker.interface] Pull image homeassistant/amd64-hassio-supervisor tag 184.
19-08-26 21:49:44 ERROR (SyncWorker_7) [hassio.docker.interface] Can't install homeassistant/amd64-hassio-supervisor:184 -> 404 Client Error: Not Found ("no such image: homeassistant/amd64-hassio-supervisor:184: No such image: homeassistant/amd64-hassio-supervisor:184").
19-08-26 21:49:44 ERROR (MainThread) [hassio.supervisor] Update of Hass.io fails!
I had this too. Ran Hass.io in Virtualbox for months without any problem, but recently it suddenly refused to install the upgrade to 0.97.2. Tried a couple of things, but in the end only a clean install followed by a restore of the latest snapshot (without HA 0.97.1 itself) did the trick.
I wasn’t able to update on 0.96, tried everything and finally did a fresh install and manually added everything back.
Then on 0.97.2 I was again unable to update! And soon after the whole system crashed ! Had to again do a fresh install and manually install everything back. It’s been working fine since.
