I am totally stuck on Home Assistant Core 2026.5.0 .
I have tried updating from the GUI but it gets to 100% and then shows that it didn't update.
Tried the command line interface (CLI via Advanced SSH & Web Terminal). It actually says it was successful but the GUI shows it is still stuck on 2026.5.0 .
I tried to downgrade to 2026.4.4 via the CLI and again it said it was successful but the GUI still shows it is stuck on 2026.5.0 .
I tried to upgrade in safe mode but still no cigar.
Everything else can update just fine (NodeRed, Apps, Supervisor, etc.)
Logger: homeassistant.components.websocket_api.http.connection
Source: components/websocket_api/commands.py:332
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: June 12, 2026 at 11:22:07 PM (1 occurrence)
Last logged: June 12, 2026 at 11:22:07 PM
[140157293690720] Error during service call to update.install: Error updating Home Assistant Core: Downloading Home Assistant version 2026.6.3 failed
Yes, it does sound like it has a connection problem, except that it can download and install updates for everything else. I'm on fiber and everything works fine. Which makes me think all the Core updates for my type of machine are corrupt, incomplete, or are on a bad server. CPU architecture x86_64
sorry for to up this old topic but I’m in exactly same point than you with 2026.9.1 core version (from 2026.8.3) with my HA Green. I’ve tried everything I know but nothing works. Just to know if you already accomplish to install finally with some trick.
My logs have 2 issues, first is “[hass_nabucasa.iot] Unable to connect: Cannot connect to host cloud.nabucasa.com:443 ssl:default [Timeout while contacting DNS servers]” but I can download other integrations without any issue with google DNS.
Also there is Error doing job: Unclosed client session (task: None) but nothing looks running apparently.
RAM and MMC are enough free (about 18gb)
