Hi, I am running HA on Virtualbox for the first time. After installation, I received the following error while updating the OS.
Failed to update. Unknown error, See supervisor
This is my log:
20-11-25 21:49:12 ERROR (MainThread) [supervisor.utils.json] Can’t read json from /data/addons/core/duckdns/config.json: Expecting value: line 1 column 1 (char 0)
20-11-25 21:49:12 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/core/duckdns/config.json from repository core
20-11-25 21:49:12 ERROR (MainThread) [supervisor.utils.json] Can’t read json from /data/addons/core/cec_scan/config.json: Expecting value: line 1 column 1 (char 0)
20-11-25 21:49:12 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/core/cec_scan/config.json from repository core
20-11-25 21:49:12 ERROR (MainThread) [supervisor.utils.json] Can’t read json from /data/addons/core/samba/config.json: Expecting value: line 1 column 1 (char 0)
20-11-25 21:49:12 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/core/samba/config.json from repository core
20-11-25 21:49:12 ERROR (MainThread) [supervisor.utils.json] Can’t read json from /data/addons/core/configurator/config.json: Expecting value: line 1 column 1 (char 0)
20-11-25 21:49:12 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/core/configurator/config.json from repository core
20-11-25 21:49:12 ERROR (MainThread) [supervisor.utils.json] Can’t read json from /data/addons/core/almond/config.json: Expecting value: line 1 column 1 (char 0)
20-11-25 21:49:12 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/core/almond/config.json from repository core
20-11-25 21:49:12 ERROR (MainThread) [supervisor.utils.json] Can’t read json from /data/addons/core/rpc_shutdown/config.json: Expecting value: line 1 column 1 (char 0)
20-11-25 21:49:12 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/core/rpc_shutdown/config.json from repository core
20-11-25 21:49:12 ERROR (MainThread) [supervisor.utils.json] Can’t read json from /data/addons/core/git_pull/config.json: Expecting value: line 1 column 1 (char 0)
20-11-25 21:49:12 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/core/git_pull/config.json from repository core
20-11-25 21:49:12 ERROR (MainThread) [supervisor.utils.json] Can’t read json from /data/addons/core/check_config/config.json: Expecting value: line 1 column 1 (char 0)
20-11-25 21:49:12 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/core/check_config/config.json from repository core
20-11-25 21:49:12 ERROR (MainThread) [supervisor.utils.json] Can’t read json from /data/addons/core/mariadb/config.json: Expecting value: line 1 column 1 (char 0)
20-11-25 21:49:12 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/core/mariadb/config.json from repository core
20-11-25 21:49:12 ERROR (MainThread) [supervisor.utils.json] Can’t read json from /data/addons/core/ada/config.json: Expecting value: line 1 column 1 (char 0)
20-11-25 21:49:12 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/core/ada/config.json from repository core
20-11-25 21:49:12 ERROR (MainThread) [supervisor.utils.json] Can’t read json from /data/addons/core/ssh/config.json: Expecting value: line 1 column 1 (char 0)
20-11-25 21:49:12 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/core/ssh/config.json from repository core
20-11-25 21:49:12 ERROR (MainThread) [supervisor.utils.json] Can’t read json from /data/addons/core/tellstick/config.json: Expecting value: line 1 column 1 (char 0)
20-11-25 21:49:12 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/core/tellstick/config.json from repository core
20-11-25 21:49:12 ERROR (MainThread) [supervisor.utils.json] Can’t read json from /data/addons/core/homematic/config.json: Expecting value: line 1 column 1 (char 0)
20-11-25 21:49:12 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/core/homematic/config.json from repository core
20-11-25 21:49:12 ERROR (MainThread) [supervisor.utils.json] Can’t read json from /data/addons/core/mosquitto/config.json: Expecting value: line 1 column 1 (char 0)
20-11-25 21:49:12 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/core/mosquitto/config.json from repository core
20-11-25 21:49:12 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/core repository
20-11-25 21:49:12 INFO (MainThread) [supervisor.store.git] Cloning add-on GitHub - hassio-addons/repository: Home Assistant Community Add-ons repository
20-11-25 21:49:14 ERROR (MainThread) [supervisor.utils.json] Can’t read json from /data/addons/core/zwave/config.json: Expecting value: line 1 column 1 (char 0)
20-11-25 21:49:14 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/core/zwave/config.json from repository core
20-11-25 21:49:14 ERROR (MainThread) [supervisor.utils.json] Can’t read json from /data/addons/core/nginx_proxy/config.json: Expecting value: line 1 column 1 (char 0)
20-11-25 21:49:14 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/core/nginx_proxy/config.json from repository core
20-11-25 21:49:14 ERROR (MainThread) [supervisor.utils.json] Can’t read json from /data/addons/core/dhcp_server/config.json: Expecting value: line 1 column 1 (char 0)
20-11-25 21:49:14 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/core/dhcp_server/config.json from repository core
20-11-25 21:49:14 ERROR (MainThread) [supervisor.utils.json] Can’t read json from /data/addons/core/dnsmasq/config.json: Expecting value: line 1 column 1 (char 0)
20-11-25 21:49:14 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/core/dnsmasq/config.json from repository core
20-11-25 21:49:14 ERROR (MainThread) [supervisor.utils.json] Can’t read json from /data/addons/core/google_assistant/config.json: Expecting value: line 1 column 1 (char 0)
20-11-25 21:49:14 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/core/google_assistant/config.json from repository core
20-11-25 21:49:14 ERROR (MainThread) [supervisor.utils.json] Can’t read json from /data/addons/core/letsencrypt/config.json: Expecting value: line 1 column 1 (char 0)
20-11-25 21:49:14 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/core/letsencrypt/config.json from repository core
20-11-25 21:49:14 ERROR (MainThread) [supervisor.utils.json] Can’t read json from /data/addons/core/deconz/config.json: Expecting value: line 1 column 1 (char 0)
20-11-25 21:49:14 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/core/deconz/config.json from repository core
20-11-25 21:49:14 ERROR (MainThread) [supervisor.utils.json] Can’t read json from /data/addons/core/duckdns/config.json: Expecting value: line 1 column 1 (char 0)
20-11-25 21:49:14 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/core/duckdns/config.json from repository core
20-11-25 21:49:14 ERROR (MainThread) [supervisor.utils.json] Can’t read json from /data/addons/core/cec_scan/config.json: Expecting value: line 1 column 1 (char 0)
20-11-25 21:49:14 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/core/cec_scan/config.json from repository core
20-11-25 21:49:14 ERROR (MainThread) [supervisor.utils.json] Can’t read json from /data/addons/core/samba/config.json: Expecting value: line 1 column 1 (char 0)
20-11-25 21:49:14 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/core/samba/config.json from repository core
20-11-25 21:49:14 ERROR (MainThread) [supervisor.utils.json] Can’t read json from /data/addons/core/configurator/config.json: Expecting value: line 1 column 1 (char 0)
20-11-25 21:49:14 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/core/configurator/config.json from repository core
20-11-25 21:49:14 ERROR (MainThread) [supervisor.utils.json] Can’t read json from /data/addons/core/almond/config.json: Expecting value: line 1 column 1 (char 0)
20-11-25 21:49:14 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/core/almond/config.json from repository core
20-11-25 21:49:14 ERROR (MainThread) [supervisor.utils.json] Can’t read json from /data/addons/core/rpc_shutdown/config.json: Expecting value: line 1 column 1 (char 0)
20-11-25 21:49:14 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/core/rpc_shutdown/config.json from repository core
20-11-25 21:49:14 ERROR (MainThread) [supervisor.utils.json] Can’t read json from /data/addons/core/git_pull/config.json: Expecting value: line 1 column 1 (char 0)
20-11-25 21:49:14 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/core/git_pull/config.json from repository core
20-11-25 21:49:14 ERROR (MainThread) [supervisor.utils.json] Can’t read json from /data/addons/core/check_config/config.json: Expecting value: line 1 column 1 (char 0)
20-11-25 21:49:14 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/core/check_config/config.json from repository core
20-11-25 21:49:14 ERROR (MainThread) [supervisor.utils.json] Can’t read json from /data/addons/core/mariadb/config.json: Expecting value: line 1 column 1 (char 0)
20-11-25 21:49:14 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/core/mariadb/config.json from repository core
20-11-25 21:49:14 ERROR (MainThread) [supervisor.utils.json] Can’t read json from /data/addons/core/ada/config.json: Expecting value: line 1 column 1 (char 0)
20-11-25 21:49:14 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/core/ada/config.json from repository core
20-11-25 21:49:14 ERROR (MainThread) [supervisor.utils.json] Can’t read json from /data/addons/core/ssh/config.json: Expecting value: line 1 column 1 (char 0)
20-11-25 21:49:14 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/core/ssh/config.json from repository core
20-11-25 21:49:14 ERROR (MainThread) [supervisor.utils.json] Can’t read json from /data/addons/core/tellstick/config.json: Expecting value: line 1 column 1 (char 0)
20-11-25 21:49:14 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/core/tellstick/config.json from repository core
20-11-25 21:49:14 ERROR (MainThread) [supervisor.utils.json] Can’t read json from /data/addons/core/homematic/config.json: Expecting value: line 1 column 1 (char 0)
20-11-25 21:49:14 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/core/homematic/config.json from repository core
20-11-25 21:49:14 ERROR (MainThread) [supervisor.utils.json] Can’t read json from /data/addons/core/mosquitto/config.json: Expecting value: line 1 column 1 (char 0)
20-11-25 21:49:14 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/core/mosquitto/config.json from repository core
20-11-25 21:49:14 INFO (MainThread) [supervisor.store] Loading add-ons from store: 45 all - 45 new - 0 remove
20-11-25 21:49:14 INFO (MainThread) [supervisor.addons] Found 0 installed add-ons
20-11-25 21:49:14 INFO (MainThread) [supervisor.snapshots] Found 0 snapshot files
20-11-25 21:49:14 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
20-11-25 21:49:14 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
20-11-25 21:49:14 INFO (MainThread) [main] Running Supervisor
20-11-25 21:49:14 INFO (MainThread) [supervisor.hassos] Rauc: A - marked slot kernel.0 as good
20-11-25 21:49:14 INFO (MainThread) [supervisor.addons] Phase ‘AddonStartup.INITIALIZE’ starting 0 add-ons
20-11-25 21:49:14 INFO (MainThread) [supervisor.addons] Phase ‘AddonStartup.SYSTEM’ starting 0 add-ons
20-11-25 21:49:14 INFO (MainThread) [supervisor.addons] Phase ‘AddonStartup.SERVICES’ starting 0 add-ons
20-11-25 21:49:14 INFO (SyncWorker_0) [supervisor.docker.interface] Starting homeassistant
20-11-25 21:49:14 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
20-11-25 21:49:26 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
20-11-25 21:49:26 INFO (MainThread) [supervisor.homeassistant.core] Detect a running Home Assistant instance
20-11-25 21:49:26 INFO (MainThread) [supervisor.addons] Phase ‘AddonStartup.APPLICATION’ starting 0 add-ons
20-11-25 21:49:26 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
20-11-25 21:49:26 INFO (MainThread) [supervisor.misc.hwmon] Started Supervisor hardware monitor
20-11-25 21:49:26 INFO (MainThread) [supervisor.core] Supervisor is up and running
20-11-25 21:49:26 INFO (MainThread) [supervisor.host.info] Updating local host information
20-11-25 21:49:26 INFO (MainThread) [supervisor.host.services] Updating service information
20-11-25 21:49:26 INFO (MainThread) [supervisor.host.network] Updating local network information
20-11-25 21:49:26 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
20-11-25 21:49:50 INFO (MainThread) [supervisor.snapshots] Found 0 snapshot files
20-11-25 21:50:15 INFO (MainThread) [supervisor.hassos] Fetch OTA update from https://github.com/home-assistant/operating-system/releases/download/None/hassos_ova-None.raucb
20-11-25 21:59:13 INFO (MainThread) [supervisor.snapshots] Found 0 snapshot files
20-11-25 22:00:16 INFO (MainThread) [supervisor.snapshots] Found 0 snapshot files
