I have an ESP-01S board, it works fine to update if it’s plugged in using a USB programmer. But when I try to run OTA it won’t update. It just says the below:
INFO Successfully compiled program.
INFO Connecting to 10.1.2.9
INFO Uploading .esphome/build/temp/.pioenvs/temp/firmware.bin (531232 bytes)
INFO Compressed to 379130 bytes
Uploading: [= ] 2%
ERROR Error sending data: [Errno 104] Connection reset by peer
Here is my yml file:
esphome:
esp8266:
board: esp01_1m
wifi:
ssid: my_ssid
password: "password"
fast_connect: true
captive_portal:
logger:
ota:
safe_mode: true
reboot_timeout: 10min
num_attempts: 5
web_server:
port: 80
It does have 1M of memory, so I know it’s not out. And the Web portal works just fine.
