Can't update some device in 2025.2.2
Hi there,
Since the update to 2025.2.2 I can’s update some of my ESP devices.
I get this message:
INFO ESPHome 2025.2.2
INFO Reading configuration /config/esphome/relay.yaml...
ERROR Unexpected exception while reading configuration:
  File "/usr/local/bin/esphome", line 8, in <module>
    sys.exit(main())
  File "/esphome/esphome/__main__.py", line 1049, in main
    return run_esphome(sys.argv)
  File "/esphome/esphome/__main__.py", line 1027, in run_esphome
    config = read_config(dict(args.substitution) if args.substitution else {})
  File "/esphome/esphome/config.py", line 1095, in read_config
    res = load_config(command_line_substitutions)
  File "/esphome/esphome/config.py", line 949, in load_config
    return _load_config(command_line_substitutions)
  File "/esphome/esphome/config.py", line 939, in _load_config
    return validate_config(config, command_line_substitutions)
  File "/esphome/esphome/config.py", line 835, in validate_config
    target_platform = core_config.preload_core_config(config, result)
  File "/esphome/esphome/core/config.py", line 222, in preload_core_config
    if _is_target_platform(domain):
  File "/esphome/esphome/core/config.py", line 184, in _is_target_platform
    if get_component(name, True).is_target_platform:
  File "/esphome/esphome/loader.py", line 205, in get_component
    return _lookup_module(domain, exception)
  File "/esphome/esphome/loader.py", line 181, in _lookup_module
    module = importlib.import_module(f"esphome.components.{domain}")
  File "/usr/lib/python3.11/importlib/__init__.py", line 126, in import_module
    return _bootstrap._gcd_import(name[level:], package, level)
  File "<frozen importlib._bootstrap>", line 1206, in _gcd_import
  File "<frozen importlib._bootstrap>", line 1178, in _find_and_load
  File "<frozen importlib._bootstrap>", line 1142, in _find_and_load_unlocked
ModuleNotFoundError: No module named 'esphome.components.ESP8266'
Has anyone a solution for this?
Cheers Bas
You have this in your YAML:
ESP8266:
That should be lowercase:
esp8266:
thank you big time
Stupid :frowning:
