Can't update to 2023.11.1?
Running HA on a rPi 4b for years now. Have it running off an SSD with 200gb free. I am currently on 2023.11.0 and have tried twice over the past 4 days to update to 2023.11.1
Both times the backup takes place and the update seems to work with restart and everything but when HA is finished restarting, I still see an orange 1 next to Settings informed me that there is an update available for 2023.11.1
Also, each time, I have lost all Zwave entries (unavailable) until I do a full restart of the system (not just HA). My Wave runs via the Zwave JS UI add-on
Any thoughts/suggestions?
Which HA install are you running?
  • Core2023.11.0
  • Supervisor2023.11.0
  • Operating System11.1
  • Frontend20231030.1
So I just tried to update to 2023.11.2
Made a backup and downloaded just in case
Updated and all seemed to work…
But then the system restarted on its own and reverted to 2023.11.0!
Logs (don’t see anything obvious but not good at reading these):
Home Assistant Core
2023-11-11 11:33:48.763 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration plex_recently_added which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-11-11 11:33:48.765 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration meross_cloud which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-11-11 11:33:48.767 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration trakt which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-11-11 11:33:48.769 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration bhyve which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-11-11 11:33:48.771 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration tesla_custom which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-11-11 11:33:48.773 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-11-11 11:33:48.775 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration awnet_local which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-11-11 11:33:48.777 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration wundergroundpws which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-11-11 11:33:48.780 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration emporia_vue which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-11-11 11:33:54.266 WARNING (Recorder) [homeassistant.components.recorder.util] The system could not validate that the sqlite3 database at //config/home-assistant_v2.db was shutdown cleanly
2023-11-11 11:33:54.311 WARNING (Recorder) [homeassistant.components.recorder.util] Ended unfinished session (id=288 from 2023-11-11 16:18:33.632244)
2023-11-11 11:33:59.015 ERROR (MainThread) [frontend.js.latest.202310301] Uncaught error from Safari 17.1 on Mac OS 10.15.7
ReferenceError: Can’t find variable: Polymer
module code (/local/battery-entity.js:1:36)
2023-11-11 11:34:12.389 ERROR (MainThread) [custom_components.wundergroundpws.coordinator] Error fetching WUnderground data: TimeoutError()
2023-11-11 11:34:12.405 ERROR (MainThread) [homeassistant.components.sensor] Error while setting up wundergroundpws platform for sensor
File “/usr/src/homeassistant/homeassistant/helpers/entity_platform.py”, line 359, in _async_setup_platform
await asyncio.shield(task)
File “/config/custom_components/wundergroundpws/sensor.py”, line 46, in async_setup_entry
sensors = [
File “/config/custom_components/wundergroundpws/sensor.py”, line 47, in
WundergroundPWSSensor(coordinator, description) for description in SENSOR_DESCRIPTIONS
File “/config/custom_components/wundergroundpws/sensor.py”, line 116, in init
self._sensor_data = _get_sensor_data(
File “/config/custom_components/wundergroundpws/sensor.py”, line 180, in _get_sensor_data
return sensors[FIELD_OBSERVATIONS][0][kind]
TypeError: ‘NoneType’ object is not subscriptable
2023-11-11 11:34:12.414 ERROR (MainThread) [homeassistant.components.weather] Error adding entities for domain weather with platform wundergroundpws
File “/usr/src/homeassistant/homeassistant/helpers/entity_platform.py”, line 507, in async_add_entities
await asyncio.gather(*tasks)
File “/usr/src/homeassistant/homeassistant/helpers/entity_platform.py”, line 752, in _async_add_entity
await entity.add_to_platform_finish()
File “/usr/src/homeassistant/homeassistant/helpers/entity.py”, line 1023, in add_to_platform_finish
self.async_write_ha_state()
File “/usr/src/homeassistant/homeassistant/helpers/entity.py”, line 743, in async_write_ha_state
self._async_write_ha_state()
File “/usr/src/homeassistant/homeassistant/helpers/entity.py”, line 843, in _async_write_ha_state
state, attr = self._async_generate_attributes()
File “/usr/src/homeassistant/homeassistant/helpers/entity.py”, line 784, in _async_generate_attributes
state = self._stringify_state(available)
File “/usr/src/homeassistant/homeassistant/helpers/entity.py”, line 749, in _stringify_state
if (state := self.state) is None:
File “/usr/src/homeassistant/homeassistant/components/weather/init.py”, line 960, in state
return self.condition
File “/config/custom_components/wundergroundpws/weather.py”, line 163, in condition
day = self.coordinator.get_forecast(FIELD_FORECAST_ICONCODE)
File “/config/custom_components/wundergroundpws/coordinator.py”, line 214, in get_forecast
return self.data[FIELD_DAYPART][0][field][period]
2023-11-11 11:34:12.430 ERROR (MainThread) [homeassistant.components.weather] Error while setting up wundergroundpws platform for weather
File “/usr/src/homeassistant/homeassistant/helpers/entity_platform.py”, line 367, in _async_setup_platform
await asyncio.gather(*pending)
2023-11-11 11:34:58.124 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: raspberry_pi
2023-11-11 11:35:58.216 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: raspberry_pi
2023-11-11 11:36:58.290 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: raspberry_pi
2023-11-11 11:37:58.357 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: raspberry_pi
2023-11-11 11:38:11.048 ERROR (MainThread) [frontend.js.latest.202310301] Uncaught error from Safari 17.1 on Mac OS 10.15.7
2023-11-11 11:38:58.429 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: raspberry_pi
2023-11-11 11:39:10.561 WARNING (MainThread) [py.warnings] /config/custom_components/bhyve/sensor.py:155: RuntimeWarning: coroutine ‘BHyveWebsocketEntity.async_update’ was never awaited
super().async_update()
Your database is corrupt. Possibly system was forcibly restarted while SQLite was updating.
Thanks for interpreting that.
Fixable with an install and restore or need to find a version to restore that is older?
Nevermind, looks like I fixed it by adding MariaDB add-on and one word in the configuration.yaml
recorder:
(well and link to the MariaDB pw…)
Boot is faster now too
Successfully on 2023.11.2
Hoping it holds…
